跳转到主内容
视频概述
本篇指南是分解流程而非维修指南。 如果您要维修您的Xbox Controller,应参考我们的维修指南
  1. Xbox One Wireless Controller Teardown, Xbox One Wireless Controller Teardown: 步骤 1 中的图像 1,1
    • First take off the back two pieces, you might need something to stick in in order to pop them out
  2. Xbox One Wireless Controller Teardown: 步骤 2 中的图像 1,1
    • Screw off all the screws, 1 screw is in the middle, and the 4 other screws are in each corner
  3. Xbox One Wireless Controller Teardown: 步骤 3 中的图像 1,2 Xbox One Wireless Controller Teardown: 步骤 3 中的图像 2,2
    • After all the screws are off, now you can pop off the front plastic plate
  4. Xbox One Wireless Controller Teardown: 步骤 4 中的图像 1,2 Xbox One Wireless Controller Teardown: 步骤 4 中的图像 2,2
    • Not you can pop off the back plate
  5. Xbox One Wireless Controller Teardown: 步骤 5 中的图像 1,1
    • So how does the electricity works;It uses electricity from the batteries. Also how it works; when you press a button it will stop the electricity and transmit inputs into the game
  6. Xbox One Wireless Controller Teardown: 步骤 6 中的图像 1,1
    • STICKS - The Sticks are the same 10k POT style as previous controllers, but are new and smaller than the 360 versions. They have a 1.8v AN+ that comes from a Regulator (U8) and it's also the vRef for U1 on the MCU board.
  7. Xbox One Wireless Controller Teardown: 步骤 7 中的图像 1,1
    • The Triggers use Linear Hall Sensors now, U10 (RT) and U11 (LT). They have 3 pins, 1 - VDD (power), 2 - Output, 3 - VSS (ground). The VDD for them comes from U9, which is turned on/off by U1 at 125Hz, 8ms period, On ~1.4ms, Off ~6.6ms (~18% Duty Cycle). This is done mainly to save power.
  8. Xbox One Wireless Controller Teardown: 步骤 8 中的图像 1,1
    • The Power board has 3 parts U1 is for when the USB cable is attached, it takes the 5v and knocks it down to ~3v for the other two circuits. U2 is for a 3.5v source that powers the LED, IR LEDs and the Rumble motors. It's TP7 on the MCU board. U3 is for the 3.3v source that powers pretty much everything on the MCU board. It's TP9 on the MCU board.
Rodulfo Macaalay
于04/20/19注册
167 声望
撰写一个指南
2条评论
A lot of help, thanks. I got an elite 2 so figured if see whats inside my stock boy
Nicholas Pratt III - 回复
Well, I was looking for an actual teardown, but it just stops after taking the outer shell off and just talks about some of the internals. Needed the instructions for a full teardown to fix face buttons.
Marques Jones - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 22
过去 30 天: 71
总计 3,206
