跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Xbox 360 Wireless Controller,请使用我们的维修手册
  1. Xbox 360 Wireless Controller Teardown, Introduction: 步骤 1 中的图像 1,1
    • Remove 7 screws located on the back of the controller using the TR-9 Toolbit
  2. Xbox 360 Wireless Controller Teardown, Removing Analog Sticks: 步骤 2 中的图像 1,3 Xbox 360 Wireless Controller Teardown, Removing Analog Sticks: 步骤 2 中的图像 2,3 Xbox 360 Wireless Controller Teardown, Removing Analog Sticks: 步骤 2 中的图像 3,3
    • Then take off and replace the analog sticks if they arent functioning correctly.
  3. Xbox 360 Wireless Controller Teardown, Removing D-Pad: 步骤 3 中的图像 1,1
    • Remove two screws from the D-Pad using a Phillips #0 Screwdriver, After doing so, you will see two latches underneath the screws that you just removed and you have to press the two latches at the same time to completely remove the D-Pad.
  4. Xbox 360 Wireless Controller Teardown, All of the Xbox 360 controller parts: 步骤 4 中的图像 1,2 Xbox 360 Wireless Controller Teardown, All of the Xbox 360 controller parts: 步骤 4 中的图像 2,2
    • If you followed these directions successfully this is what the final result should look like.
  5. Xbox 360 Wireless Controller Teardown: 步骤 5 中的图像 1,1
    • Full IC Identification:
    • You may need to enlarge it to view the text.
RareWarrior123
于04/26/19注册
119 声望
撰写一个指南
一条评论
man this taredown is terrable . tr9 not t3 from the start .. .. man should just take it down and try again
Dub Lux - 回复
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 57
过去 30 天: 236
总计 7,823
