跳转到主内容
你所需要的
本篇指南是分解流程而非维修指南。 如果您要维修您的Wahl Cordless Beard Trimmer,应参考我们的维修指南
  1. Wahl Cordless Beard Trimmer Teardown, Remove battery cover: 步骤 1 中的图像 1,2 Wahl Cordless Beard Trimmer Teardown, Remove battery cover: 步骤 1 中的图像 2,2
    • Begin by removing the battery cover from the back of the trimmer.
  2. Wahl Cordless Beard Trimmer Teardown, Remove battery: 步骤 2 中的图像 1,2 Wahl Cordless Beard Trimmer Teardown, Remove battery: 步骤 2 中的图像 2,2
    • Remove the battery.
  3. Wahl Cordless Beard Trimmer Teardown, Remove metal blade: 步骤 3 中的图像 1,3 Wahl Cordless Beard Trimmer Teardown, Remove metal blade: 步骤 3 中的图像 2,3 Wahl Cordless Beard Trimmer Teardown, Remove metal blade: 步骤 3 中的图像 3,3
    • Remove the screws, then gently lift off the blade. A small piece of plastic should come off with the blade. There will be a spring revealed from under the blade, remove this as well.
  4. Wahl Cordless Beard Trimmer Teardown, Separate plastic cover: 步骤 4 中的图像 1,2 Wahl Cordless Beard Trimmer Teardown, Separate plastic cover: 步骤 4 中的图像 2,2
    • Remove the screws from the sides of the battery compartment. Then, gently separate the two halves of the plastic cover.
  5. Wahl Cordless Beard Trimmer Teardown, Remove switch: 步骤 5 中的图像 1,2 Wahl Cordless Beard Trimmer Teardown, Remove switch: 步骤 5 中的图像 2,2
    • Lay both halves of the trimmer out, and remove the switch from the inside of the white plastic cover.
  6. Wahl Cordless Beard Trimmer Teardown, Remove motor: 步骤 6 中的图像 1,2 Wahl Cordless Beard Trimmer Teardown, Remove motor: 步骤 6 中的图像 2,2
    • Finally, remove the motor from the black plastic cover. If desired, this motor can be de-soldered from the red wire and re-purposed.
arielletc28
于11/28/18注册
167 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 35
过去 30 天: 181
总计 17,067
