跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的W8 Android Smart Watch,请使用我们的维修手册
  1. W8 Android Smart Watch Teardown, Requirements: 步骤 1 中的图像 1,2 W8 Android Smart Watch Teardown, Requirements: 步骤 1 中的图像 2,2
    • For the teardown I'll be using the iFixIt Protech Toolkit. It has everything I need and all tools required to do the teardown
  2. W8 Android Smart Watch Teardown, The Product: 步骤 2 中的图像 1,2 W8 Android Smart Watch Teardown, The Product: 步骤 2 中的图像 2,2
    • Here it is, the W8 Android Smart Watch.
  3. W8 Android Smart Watch Teardown, Taking off the back: 步骤 3 中的图像 1,2 W8 Android Smart Watch Teardown, Taking off the back: 步骤 3 中的图像 2,2
    • The first step doesn't require any tools.
    • On the back you can take off the back in the left-bottom corner
  4. W8 Android Smart Watch Teardown, Battery Removal: 步骤 4 中的图像 1,2 W8 Android Smart Watch Teardown, Battery Removal: 步骤 4 中的图像 2,2
    • Something we haven't seen since iPhone got invented. Removable and Replacable battery
    • Under the battery you'll find a slot for a Micro SD card (Not included, added it myself) and a SIM card slot
  5. W8 Android Smart Watch Teardown, Vibration Motor Removal: 步骤 5 中的图像 1,2 W8 Android Smart Watch Teardown, Vibration Motor Removal: 步骤 5 中的图像 2,2
    • Now we have to remove the vibration motor, don't be fooled (Like I was), this is NOT a battery! (Thanks for correcting me Pawel)
    • For this I used a simple tweezers
  6. W8 Android Smart Watch Teardown, Screws Removal: 步骤 6 中的图像 1,3 W8 Android Smart Watch Teardown, Screws Removal: 步骤 6 中的图像 2,3 W8 Android Smart Watch Teardown, Screws Removal: 步骤 6 中的图像 3,3
    • Next we need to remove the 4 screws in the corners, These can be removed with a 00 head
  7. W8 Android Smart Watch Teardown, Screws Removal (2): 步骤 7 中的图像 1,2 W8 Android Smart Watch Teardown, Screws Removal (2): 步骤 7 中的图像 2,2
    • One more
    • And now.
  8. W8 Android Smart Watch Teardown, Taking off the cover: 步骤 8 中的图像 1,2 W8 Android Smart Watch Teardown, Taking off the cover: 步骤 8 中的图像 2,2
    • With the 4 screws removed, we can remove the top layer.
    • On the bottom and on the left top there's the speaker
    • Is this what they mean with integrated audio?
  9. W8 Android Smart Watch Teardown, Taking off the bands: 步骤 9 中的图像 1,3 W8 Android Smart Watch Teardown, Taking off the bands: 步骤 9 中的图像 2,3 W8 Android Smart Watch Teardown, Taking off the bands: 步骤 9 中的图像 3,3
    • We can now also remove the band from the watch.
    • If we look closer, inside the band, there's the GSM Antenna (Thanks for the tip Pawel!)
  10. W8 Android Smart Watch Teardown, Plastic covers, our worst enemy.: 步骤 10 中的图像 1,2 W8 Android Smart Watch Teardown, Plastic covers, our worst enemy.: 步骤 10 中的图像 2,2
    • If there's anything that can't stop us at iFixIt, it's gotta be this. Simply use the Tweezers from your iFixIt Protech Toolkit and your good to go
  11. W8 Android Smart Watch Teardown, Removing the cables and the board: 步骤 11 中的图像 1,3 W8 Android Smart Watch Teardown, Removing the cables and the board: 步骤 11 中的图像 2,3 W8 Android Smart Watch Teardown, Removing the cables and the board: 步骤 11 中的图像 3,3
    • Before taking off the board, there's 2 cables you need to unplug first!
    • Note the 2 cables are locked so you'll need to simply push up the lock so you can take out the cables, do this with accuracy and precision, using Tweezers!
    • Now we can take out the board!
  12. W8 Android Smart Watch Teardown, Finished!: 步骤 12 中的图像 1,1
    • And now we've come to the end.
    • In such a small device, so much functions. We've learned a lot today.
    • We also learned that a iPhone 5C Camera is no good at taking pictures at close distance!
Lena Fox
于12/12/17注册
808 声望
撰写一个指南
团队
Kid fixers Kid fixers 的会员
Community
154 名成员
创作了291篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 24
过去 30 天: 43
总计 3,908
