此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论。
简介
本指南介绍了如何拆解 Vtech Kidizoom 相机。
你所需要的
Pour réassembler votre appareil, suivez les instructions dans l'ordre inverse.
13等其他人完成本指南。
5指南评论
In the very first step be aware that the you just need to remove the paper ring. In the photo above this is pink and on mine it was orange.
I made the mistake of thinking I had to use some force with a screwdriver, to remove the ring on the front, which resulted in me scratching the chrome ring.
Once you have removed the paper ring, you can see the screws (or they may be under the left over sticky backing to the paper but are easy to find).
These photos were extremely helpful and I was able to repair the camera.
The problem with mine, was that it would not switch on. We replaced the batteries, but still no good.
After using the above photos, I opened the camera and discovered that one of the two cables to one of the battery holders, had come loose.
In the process of resoldering the broken cable, the second battery cable also came off … mainly due to the use of VERY thin wire and minimum solder.
Anyway, the camera is now working again and my son is very happy.
Thanks! I had the newer Kidzoom touch 5.0 model. It works similar but after the same principle: First remove the camera objective ring. I could repair the (mechanical) damage…
Klausklaus - 回复 分享
Thanks a lot, also in my case the trigger button of the kidizoom touch 5.0 was stuck. I followed the instruction and was able to fix it. Thereby I scratched a bit the silver ring. This may could be prevented if the locator of the notches are known/considered while trying to remove the outer ring.
Hi, has anyone any experience of taking the Vtech Kidizoom Action Cam HD apart mine charges but will not switch on (loose wire i suspect) but i can't see how to disassemble. Cheers Alan.
