跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Uniden EXP 371,请使用我们的维修手册
  1. Uniden EXP 371 Teardown, Uniden EXP 371 Teardown: 步骤 1 中的图像 1,1
    • Uniden EXP371 900 MHz Cordless Phone.
    • 900 MHz Extended Range with One Touch RocketDial/Find Handset Locator and is Desk or Wall Mountable.
  2. Uniden EXP 371 Teardown: 步骤 2 中的图像 1,2 Uniden EXP 371 Teardown: 步骤 2 中的图像 2,2
    • Remove the battery by first pressing down on the rear of the cover and pushing the cover towards the bottom of the phone.
    • Next remove the battery by pulling on the connector.
  3. Uniden EXP 371 Teardown: 步骤 3 中的图像 1,2 Uniden EXP 371 Teardown: 步骤 3 中的图像 2,2
    • Next remove the two screws at the bottom of the phone with a PH1 philips screwdriver.
    • Now remove the top portion of the case from the bottom. This may be difficult to do with your bare hands. The use of a plastic opening tool may come in handy.
  4. Uniden EXP 371 Teardown: 步骤 4 中的图像 1,3 Uniden EXP 371 Teardown: 步骤 4 中的图像 2,3 Uniden EXP 371 Teardown: 步骤 4 中的图像 3,3
    • Your next step is to remove the five screws holding down the motherboard. Use the PH1 philips screwdriver.
    • Once you have removed the five screws you may lift the motherboard off of the front case.
    • At this point you may also remove the dial pad. It simply lifts off.
    • You may also remove the speaker if needed by unscrewing the two screws using the PH1 philips screwdriver.
    • The whole phone is now disassembled at this point.
Tim Reimer
于06/19/10注册
165 声望
创作了3篇指南
一条评论
this guide is poorly written, please delete or improve it.
Walker Quine - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 13
总计 4,580
