简介
This is the full teardown of Digia, Qt (Formally Trolltech) Linux based phone.
你所需要的
this picture shows the two black plastic clips wich you want du unlock if you would like to reach deeper into the interiors of this phone.
the 2e pikture show how to place the slotted pan head screwdriver
to unlock them you have to turn the screwdriver around its own axe.
when you unlocked both, go with an ipod opening tool around the 3 other sides to unlock several other plastic clips, wich shold be easy to do
now you are able to put the mainboard (the one and only), display and buttons (it appears that this is one huge part) and the black back/mid frame from each other
its easy to remove the speaker/antenna and some plastic parts from the back panel
the camera is glued on the board, but connected with an usual camera connector.
all EMI shields are brazed onto the bord.
