跳转到主内容
你所需要的
本篇指南是分解流程而非维修指南。 如果您要维修您的Thumby,应参考我们的维修指南
  1. Thumby Teardown, Thumby Teardown: 步骤 1 中的图像 1,2 Thumby Teardown, Thumby Teardown: 步骤 1 中的图像 2,2
    • Insert an opening pick to the right of the Micro USB port, and slide it around the whole frame. Be careful with the top right and bottom left corners, as to not snap off the pins.
    • To take out the motherboard, pry up on the battery. It's securely glued in place and the least fragile component.
    • When removing the motherboard, make sure the screen is facing downward. The DPAD and A/B buttons are not secured to the front in any way, and will fall out if they have nothing supporting them.
    • To assemble the Thumby, you will need glue, unless you don't mind it barely holding together.
UnRedKnown
于04/20/24注册
208 声望
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 39
总计 841
