跳转到主内容
本拆机指南正在进行中 – 定期刷新以看到更新!
你所需要的
  1. Texas Insturments TI-84 Plus Color Silver Edition Teardown, Take battery cover off: 步骤 1 中的图像 1,3 Texas Insturments TI-84 Plus Color Silver Edition Teardown, Take battery cover off: 步骤 1 中的图像 2,3 Texas Insturments TI-84 Plus Color Silver Edition Teardown, Take battery cover off: 步骤 1 中的图像 3,3
    • Wisdom
  2. Texas Insturments TI-84 Plus Color Silver Edition Teardown, Take out the battery: 步骤 2 中的图像 1,2 Texas Insturments TI-84 Plus Color Silver Edition Teardown, Take out the battery: 步骤 2 中的图像 2,2
    • Unplug the battery.
    • Be careful not to fray cable while unplugging.
  3. Texas Insturments TI-84 Plus Color Silver Edition Teardown, Remove the back cover/ front button shield: 步骤 3 中的图像 1,3 Texas Insturments TI-84 Plus Color Silver Edition Teardown, Remove the back cover/ front button shield: 步骤 3 中的图像 2,3 Texas Insturments TI-84 Plus Color Silver Edition Teardown, Remove the back cover/ front button shield: 步骤 3 中的图像 3,3
    • Remove the back cover by removing the 6 Pentalobe screws (P6)
    • The front cover can be taken off by prying it off from the front of the device
    • Then pry off the back cover it can be a little challenging but take your time
  4. Texas Insturments TI-84 Plus Color Silver Edition Teardown, Disassemble the mother board: 步骤 4 中的图像 1,3 Texas Insturments TI-84 Plus Color Silver Edition Teardown, Disassemble the mother board: 步骤 4 中的图像 2,3 Texas Insturments TI-84 Plus Color Silver Edition Teardown, Disassemble the mother board: 步骤 4 中的图像 3,3
    • Remove the 6 Philips screws holding the mother board and if you want remove the foil just to see the full board itself
    • To change out the buttons take out the grey rubber sheet that separates them from the board (be careful with the buttons as they will fall out)
ArabianBoi1259
于04/03/20注册
103 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 29
总计 422
