跳转到主内容
你所需要的
本篇指南是分解流程而非维修指南。 如果您要维修您的Remote Control,应参考我们的维修指南
  1. Tandberg Remote Teardown, Remove the IR Cap: 步骤 1 中的图像 1,3 Tandberg Remote Teardown, Remove the IR Cap: 步骤 1 中的图像 2,3 Tandberg Remote Teardown, Remove the IR Cap: 步骤 1 中的图像 3,3
    • Pop off the front cap with the metal spudger.
    • There is no adhesive; the remote and cap are just snapped together.
  2. Tandberg Remote Teardown, Remove the Batteries: 步骤 2 中的图像 1,2 Tandberg Remote Teardown, Remove the Batteries: 步骤 2 中的图像 2,2
    • Remove the back cover from the remote and take out the batteries.
  3. Tandberg Remote Teardown, Remove the Rear Screws: 步骤 3 中的图像 1,3 Tandberg Remote Teardown, Remove the Rear Screws: 步骤 3 中的图像 2,3 Tandberg Remote Teardown, Remove the Rear Screws: 步骤 3 中的图像 3,3
    • There are four screws underneath where the batteries were. Unscrew all four screws.
    • After unscrewing these four screws, proceed to pull the top apart from the bottom of the remote. This should be relatively easy, and the motherboard will now be clearly visible,
  4. Tandberg Remote Teardown, The Motherboard: 步骤 4 中的图像 1,3 Tandberg Remote Teardown, The Motherboard: 步骤 4 中的图像 2,3 Tandberg Remote Teardown, The Motherboard: 步骤 4 中的图像 3,3
    • Finally, after the top cover is removed from the remote, pop the buttons out from the plastic top shell. These buttons can be a great source of stress relief.
    • Finally, remove the motherboard. The motherboard is a single unit without daughter boards or connecting wires. However, do be careful when removing the battery terminals from the back cover.
    • Congratulations! You completed the teardown!
Greg Fairbanks
于11/16/16注册
250 声望
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 9
总计 1,706
