跳转到主内容
修复你的物品
维修的权力
商店
在此拆机指南中使用的工具
简介
Hey im Marios!I Make repairs on everythink you may have in your house!This is an easy repair but some people may want some help!Lets go!
这个拆解是不是维修指南。 要维修你的的TP-LINK Wireless 2-Way Audio Surveillance Camera,请使用我们的维修手册
  1. Remove the 2 screws holding the back cover!Should be fairly easy(You need a Phillips Screwdriver)
    • Remove the 2 screws holding the back cover!Should be fairly easy(You need a Phillips Screwdriver)
  2. This is also fairly easy to do!You can use your hands to pull it off!Put first use a flat screwdriver to open the "clips"
    • This is also fairly easy to do!You can use your hands to pull it off!Put first use a flat screwdriver to open the "clips"
  3. Remove the board from the Surveillance Camera!
    • Remove the board from the Surveillance Camera!
  4. Remove the wireless card which is hold by 2 "clips"!
    • Remove the wireless card which is hold by 2 "clips"!
  5. Remove the cable antenna now!And thats it you are done,now just follow the guide in reverse and install your new wireless card/antenna if also needed!
    • Remove the cable antenna now!And thats it you are done,now just follow the guide in reverse and install your new wireless card/antenna if also needed!
    • WARNING:DO THIS CAREFULLY!ITS SUGGESTED THAT YOU DO THIS STEP SLOWLY!TAKE YOUR TIME OR YOU MAY DAMAGE THE CABLE OR EVEN THE BOARD!
Marios
于2015年01月23日注册
64 信誉积分
撰写一个指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 1,274
