简介
My 1984 Suzuki FA50 was exhibiting some interesting problems. Although it ran fine a year ago, I could not get it running for the life of me. The problem was most likely a stuck throttle cable that I unstuck using some brute force. However, I figured it would also be nice to get my hands dirty and do an overhaul of the carburetor and engine. So here it is!
Note: The teardown was done backwards. I already disassembled the moped, and then took pictures reassembling it together. You may notice that some parts look new -- it's because they are.
Note #2: I figured it would be good to ring in the new year with a solid teardown, so I published it right on 12:00 AM PST, January 1, 2010 :)
你所需要的
There's no rage against this machine.
Looks great, except it doesn't run.
Its 50 cc engine lets me go downhill at almost 28 MPH when it does run. Uphills, not so much. Depending on the hill (and my head start), I may or may not have to walk it up.
I set aside the fuel tank and bam! -- the wires were ready to be disconnected.
The wires must have been minding their own business since '84... Separating them was quite a challenge. Thankfully they had those round connectors on them, so I didn't have to solder or crimp anything when reassembling the moped.
I paused for a minute to enjoy a cold cup of Diet Coke, and to drain all the 2-cycle oil...
I got the Goliath "freezer" mug in Six Flags Magic Mountain about 6-7 years ago. Best investment I ever made, aside from marrying the wife. It's the gift that keeps on giving!
Ikea bowls come in quite handy. Turns out there was enough 2-cycle oil to fill the entire bowl to the brim!
I wanted to see what a "flywheel magneto" looked like, so I decided to remove this cover. I figured anything named after an X-Man is worth a look...
I stripped the Phillips originals while taking the cover off. I replaced them with appropriately-sized 20 mm hex-head screws.
This is a 65 mm replacement I ordered online, along with news seals and stuff.
8条评论
I am looking for a manual how to replace my spark plug of my Suzuki FA50. Can you help me?
Do you know if the crank case would be the same for a 84 as it would be for a 83 im purchasing a new crank case for my 83 but found a 84 crank case for cheap
