你所需要的
视频概述
- This version of the Surface Go is significantly easier to open thanks to the new display adhesive and redesigned interior shields.
- The use of only one type of screw simplifies repair.
- The lack of modularity, especially on high-wear ports, makes repairs unnecessarily expensive.
- Replacement of any part requires removal of the display assembly, an easy (and expensive) part to damage.
最后的想法
可修复性评分
![](https://assets.cdn.ifixit.com/static/images/repairability_meter/meter-background.png)
![](https://assets.cdn.ifixit.com/static/images/repairability_meter/meter.png)
3
可修复性10分中得3分
(10是最容易修复)
(10是最容易修复)
7条评论
A big part of the Surface’s thermal solution is the aluminum backshell. If they added thermal pads between the back of the CPU and PMIC area of the PCB and the case, it would definitely be a nice touch.
Ethan Zuo - 回复
We’ve always got modders to do that.
Strumajen -
Does anyone knows if the battery for the surface go 1 is compatible with the surface go 2 and vice versa?
Odysseus - 回复
Is the LTE modem removable/swapable?
Dan - 回复
Unfortunately it is soldered to the motherboard
Josh *thegadget* Hymer -
