跳转到主内容
本拆机指南正在进行中 – 定期刷新以看到更新!
你所需要的
    • Be cautious when using the iOpener for opening the adhesive on the cheese packaging.
    • Inspect the string cheese packaging. You should see a perforated corner that you can stick the tip of your spudger into.
    • Once you put the tip of the spudger into the plastic pull the corner with your other hand, guiding the spudger along as you peel back the packaging.
    • We're in to the GOOD stuff,
    • Pull up on the cheese to get it unstuck from the adhesive
    • Then peal the last bits of adhesive away
    • YOU CANT PUT IT BACK TOGETHER
Ben Capehart
于06/09/21注册
7,299 声望
创作了18篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,534篇指南
19条评论
@beanman56
This it a great teardown >:-D
Can we see a teardown on a strawberry?
HelloMacOS - 回复
Sure ,what do you want me to do?
HelloMacOS -
@hellomacos - Idk do what you want X-D
Ben Capehart -
@hellomacos - Will Do! >:-D
[无效指南链接]
Ben Capehart - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 142
