拆解
This guide will walk you through the steps to completely disassemble a Sprint Airave.
这个拆解是不是维修指南。 要维修你的的Sprint Airave SCS-26UC2,请使用我们的维修手册。
Remove the external antenna, GPS cover, and GPS module.
Use a pry tool to remove the white outer cover. Pry towards the front of the device. Continue prying down the length of the cover until it pops off.
Locate and remove the four Phillips screws
With the cover removed you now have access to the circuit board.
Using an 8mm socket you can remove the antenna pigtail.
Release the clip indicate to remove the circuit board.
Here is the circuit board fully removed.
与2其他贡献者
于06/11/11注册
164 声望
撰写一个指南
徽章: 3
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 3,322
