跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Sony Walkman WM-FX20,请使用我们的维修手册
  1. Sony Walkman WM-FX20 Teardown, Sony Walkman WM-FX20 Teardown: 步骤 1 中的图像 1,1
    • Good Ole Sony Walkman.
    Make sure both batteries have been removed before you start opening the housing.
    Reiner E. Kreitner - 回复
  2. Sony Walkman WM-FX20 Teardown: 步骤 2 中的图像 1,3 Sony Walkman WM-FX20 Teardown: 步骤 2 中的图像 2,3 Sony Walkman WM-FX20 Teardown: 步骤 2 中的图像 3,3
    • Start with removing the screw on the Underside. The screw on the Backside next. Then the two on the reverse side of the tape controls.
    • New line.
  3. Sony Walkman WM-FX20 Teardown: 步骤 3 中的图像 1,3 Sony Walkman WM-FX20 Teardown: 步骤 3 中的图像 2,3 Sony Walkman WM-FX20 Teardown: 步骤 3 中的图像 3,3
    • With a small Phillips head, Pry the sides carefully.
  4. Sony Walkman WM-FX20 Teardown: 步骤 4 中的图像 1,2 Sony Walkman WM-FX20 Teardown: 步骤 4 中的图像 2,2
    • Take care not to jostle the Switches on the top of the unit while removing case. So now we have removed the underside casing from the device.
  5. Sony Walkman WM-FX20 Teardown: 步骤 5 中的图像 1,3 Sony Walkman WM-FX20 Teardown: 步骤 5 中的图像 2,3 Sony Walkman WM-FX20 Teardown: 步骤 5 中的图像 3,3
    • Find Ribbon Cable that connects to the board. Carefully Pry open either side of connector as shown, then remove ribbon cable from board.
  6. Sony Walkman WM-FX20 Teardown: 步骤 6 中的图像 1,1
    • Now we can remove the board from the casing.
  7. Sony Walkman WM-FX20 Teardown: 步骤 7 中的图像 1,3 Sony Walkman WM-FX20 Teardown: 步骤 7 中的图像 2,3 Sony Walkman WM-FX20 Teardown: 步骤 7 中的图像 3,3
    • If you do not need to replace the front door control assembly I would not suggest to continue any further- That little spring took me a good 40 minutes to properly get back in place. It is Crucial to get it in right so that the Cassette door stays flush and closed.
    • Find Door Spring and remove carefully. Then find and pry off (on either side) glued on bumpers- These limit the distance the door hinge can travel in order to be pulled off---
  8. Sony Walkman WM-FX20 Teardown: 步骤 8 中的图像 1,2 Sony Walkman WM-FX20 Teardown: 步骤 8 中的图像 2,2
    • Now gently pry the door hinges on either side off of their pivot point, and remove the front door from the assembly
  9. Sony Walkman WM-FX20 Teardown: 步骤 9 中的图像 1,3 Sony Walkman WM-FX20 Teardown: 步骤 9 中的图像 2,3 Sony Walkman WM-FX20 Teardown: 步骤 9 中的图像 3,3
    • Remove three screws on backside of cassette door. Then remove panel.
  10. Sony Walkman WM-FX20 Teardown: 步骤 10 中的图像 1,3 Sony Walkman WM-FX20 Teardown: 步骤 10 中的图像 2,3 Sony Walkman WM-FX20 Teardown: 步骤 10 中的图像 3,3
    • There is your front mounted control board! It is attached to what appears to be a speaker i'm guessing. Possibly for the alarm clock. I found that to be interesting, the little speaker thing. Anyways , thats it.
JaosnT
于10/12/09注册
414 声望
创作了5篇指南
5条评论
Please provide more info on how to put the spring back together again. I have a WM-FX435.
Robert Surya - 回复
Hi, the casette operation has failed. Now I try to check. Really I do not the reason. Any suggestion?
Batur Salamom - 回复
Thank you, my fx 20 is now like new :) Great tutorial!
kolev_art - 回复
Exactly what I needed to change the drive belts, which turned out to be super easy using these directions and excellent pictures. Thank you so much!
Tek Trekker - 回复
Great guide, much appreciated!
Makes a clean and belt change doable.
43578UMP - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 32
过去 30 天: 108
总计 25,154
