跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Sony SRS-X3,请使用我们的维修手册
  1. Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown, Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown: 步骤 1 中的图像 1,2 Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown, Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown: 步骤 1 中的图像 2,2
    • There are 6 screws under the rubber feet on the bottom. Removing them allows the bottom plate to be removed, and then from there, the front panel, front cover, and battery compartment.
    • if you need higher reslution photos please leave a comment.
  2. Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown: 步骤 2 中的图像 1,3 Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown: 步骤 2 中的图像 2,3 Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown: 步骤 2 中的图像 3,3
    • Photos of the Main PCB. IC part numbers can be read off the photos.
    • DC to DC power supply and Yamaha audio amp chip/output filter inductors are the main parts of this side
  3. Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown: 步骤 3 中的图像 1,3 Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown: 步骤 3 中的图像 2,3 Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown: 步骤 3 中的图像 3,3
    • More images of the main board assembly.
    • The pinouts of the main flex are actually stated on the board which is a huge plus.
    • A CSR Bluetooth SoC and MXIC flash are provided.
  4. Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown: 步骤 4 中的图像 1,2 Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown: 步骤 4 中的图像 2,2
    • The battery pack is on a connector and can be removed before all of this is taken out.
    • Battery is a 2 cell 18650 pack with protection built in; 7.4V
  5. Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown: 步骤 5 中的图像 1,2 Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown: 步骤 5 中的图像 2,2
    • Two 7W speakers with strong magnets are included in this speaker; it is marketed with a 20W power output. Excursion is about 7-10mm at its peak.
  6. Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown: 步骤 6 中的图像 1,2 Sony SRS-X3 Bluetooth NFC Wireless Speaker Teardown: 步骤 6 中的图像 2,2
    • Two passive radiators are present inside the device. They're fairly heavy but rubberized, and they resonate and are tuned for low frequency reproduction. These move a LOT when it's playing. 7-10mm per side.
Larry Chen
于04/22/13注册
913 声望
创作了5篇指南
10条评论
This is great, thank you Larry. I'd wondered about the possibility of upgrading the battery to one that lasts longer between charges but I had no idea how to open the case. It didn't occur to me that the screws would be under the rubber feet!
Steve MacDonald - 回复
Dear Larry, can you give me capture specific card power close to battery. Because i got resistor blown in that card, and i don't know specific value of this resistor. Many Thanks in advance
didi - 回复
One speaker started to give a lot of distortion making it unusable. Repositioned speaker in the heavy (magnet) housing and it's all good again.
Thank you for the opening tips and pics!
Albert - 回复
Larry,
My mini connector for dc into the board has broken. Replace connector or the whole Board? Where can I get a Power Board?
michael ruse - 回复
Where could I find the replacement speaker? My right speaker is buzzing a little on certain songs. Thanks!
Aaron Todd - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 10
过去 30 天: 37
总计 8,673
