跳转到主内容
修复你的物品
维修的权力
商店
简介
I have a PlayStation 1, and i have decided to make a new teardown of it.
I'm spanish, so my english is a bit poor, and sorry for the mistakes made in this teardown.
Without further delay, we start.
这个拆解是不是维修指南。 要维修你的的PlayStation,请使用我们的维修手册
  1. Here's the PS1. Turn the PS1 over and remove the six screws.
    • Here's the PS1.
    • Turn the PS1 over and remove the six screws.
    So far looking good. I'm commenting as you are making this teardown.
    Nicholas Ouimet - 回复
  2. Remove the top cover. It's very easy.
    • Remove the top cover. It's very easy.
  3. Disconnect both CD-ROM connectors.
    • Disconnect both CD-ROM connectors.
    • CD connector one and the socket it connects to.
    • CD connector two and the socket it connects to.
  4. Remove the CD-ROM reader. You should be able to pull it out gently, although you may have to wiggle it around a bit to loosen the rubber holders. Remove the CD-ROM reader. You should be able to pull it out gently, although you may have to wiggle it around a bit to loosen the rubber holders.
    • Remove the CD-ROM reader. You should be able to pull it out gently, although you may have to wiggle it around a bit to loosen the rubber holders.
  5. Detach both cables. They go to the power supply and to the memory cards and controller connectors.
    • Detach both cables. They go to the power supply and to the memory cards and controller connectors.
  6. Remove the four screws and the metal cover.
    • Remove the four screws and the metal cover.
  7. Now you have the motherboard!
    • Now you have the motherboard!
    • And the power supply.
    • Remove the four screws from the motherboard and the power supply.
  8. Once the screws are removed, remove the power supply.
    • Once the screws are removed, remove the power supply.
  9. Remove the motherboard, and both of the screws from the memory card/ controller connection mechanism.
    • Remove the motherboard, and both of the screws from the memory card/ controller connection mechanism.
  10. Now, you have all your PlayStation 1 parts!
    • Now, you have all your PlayStation 1 parts!
    • Main Board
    • Lower Casing
    • EMI Shield
    • Power Supply
    • Disk Reader
    • Memory Card/ Controller Mechanism
imacg517
于2010年05月06日注册
164 信誉积分
撰写一个指南
That’s a PAL PS1. May be different from NTSC models.
Daniel Powers - 回复
添加评论
浏览统计数据:
过去的24小时: 7
过去的7天: 34
过去的30天: 145
总计 22,507
