跳转到主内容
你所需要的
本篇指南是分解流程而非维修指南。 如果您要维修您的PlayStation,应参考我们的维修指南
  1. Sony PlayStation SCPH-9002 Teardown, Sony PlayStation SCPH-9002 Teardown: 步骤 1 中的图像 1,2 Sony PlayStation SCPH-9002 Teardown, Sony PlayStation SCPH-9002 Teardown: 步骤 1 中的图像 2,2
    • Here's the PS1.
    • Turn the PS1 over and remove the six screws.
    • Note: part number +BV 3X14
  2. Sony PlayStation SCPH-9002 Teardown: 步骤 2 中的图像 1,1
    • Remove the top cover. It's very easy.
  3. Sony PlayStation SCPH-9002 Teardown: 步骤 3 中的图像 1,1
    • Disconnect both CD-ROM connectors.
    • CD connector one and the socket it connects to.
    • CD connector two and the socket it connects to.
    • Note: part number DEVICE OPTICAL KSM-440AEM
  4. Sony PlayStation SCPH-9002 Teardown: 步骤 4 中的图像 1,2 Sony PlayStation SCPH-9002 Teardown: 步骤 4 中的图像 2,2
    • Remove the CD-ROM reader. You should be able to pull it out gently, although you may have to wiggle it around a bit to loosen the rubber holders.
  5. Sony PlayStation SCPH-9002 Teardown: 步骤 5 中的图像 1,1
    • Detach both cables. They go to the power supply and to the memory cards and controller connectors.
  6. Sony PlayStation SCPH-9002 Teardown: 步骤 6 中的图像 1,1
    • Remove the four screws and the metal cover.
  7. Sony PlayStation SCPH-9002 Teardown: 步骤 7 中的图像 1,2 Sony PlayStation SCPH-9002 Teardown: 步骤 7 中的图像 2,2
    • Now you have the motherboard!
    • And the power supply.
    • Remove the four screws from the motherboard and the power supply.
  8. Sony PlayStation SCPH-9002 Teardown: 步骤 8 中的图像 1,1
    • Once the screws are removed, remove the power supply.
  9. Sony PlayStation SCPH-9002 Teardown: 步骤 9 中的图像 1,1
    • Remove the motherboard, and both of the screws from the memory card/ controller connection mechanism.
  10. Sony PlayStation SCPH-9002 Teardown: 步骤 10 中的图像 1,1
    • Now, you have all your PlayStation 1 parts!
    • Main Board
    • Lower Casing
    • EMI Shield
    • Power Supply
    • Disk Reader
    • Memory Card/ Controller Mechanism
imacg517
于05/06/10注册
188 声望
撰写一个指南
1指南评论
That’s a PAL PS1. May be different from NTSC models.
Daniel Powers - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 27
过去 30 天: 117
总计 29,598
