简介
While I was walking around my overcrowded basement I ran into something I stopped using years ago when I bought a super technological cellphone that did everything and more than my older morning companion. After checking if it was still working i decided to tear it down and see how this little gadget saved my life so many times in the morning..
你所需要的
How many of you at least once in your life wanted to smash your alarm clock against the wall to make it stop beeping?? Well today we're gonna do something worse... we're going to tear it down!!
Let's turn the alarm clock upside down, regardless of the risk of electric shock as stated by the caution sign, we proceed using a regular Phillips screwdriver.
As you can see the Sony Dream Machine has a battery power backup just to make sure it'll ruin your dreams by going off even if the power is out! Diabolical..
Here it is.. your alarm clock split in half.
Now we need to remove the circuit board... nothing easier... just lift it from the side with your thumb and there you go!
Before we move on to the top half of the alarm clock we need to remove the AC, just like the circuit board use your thumb for some leverage and it will easily pop out of its case.
Saludos, cual es el voltaje de las dos salidas del transformador?
Please Help.i need data of transformers pin 1 2 3 4. send ur replay to agusalternative@gmail.com thanks
