跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Sony D-822K Car Discman,请使用我们的维修手册
  1. Sony D-822K Car Discman Teardown, Sony D-822K Car Discman Teardown: 步骤 1 中的图像 1,1
    • Obtain a D822-K Discman and remote. True, it has DSP and Surround Sound, but the 90's have come and gone. It's okay to take it apart.
  2. Sony D-822K Car Discman Teardown: 步骤 2 中的图像 1,1
    • Position unit so that the bottom is facing up. Remove the 6 screws.
    • Hold top and bottom of unit together as you turn the unit over, bottom facing down. Use caution; the upper and lower case, along with circuit board are now loose.
    • Watch out for the AVLS and illumination switches, they love to disappear when unsupervised. Remove top of case.
  3. Sony D-822K Car Discman Teardown: 步骤 3 中的图像 1,3 Sony D-822K Car Discman Teardown: 步骤 3 中的图像 2,3 Sony D-822K Car Discman Teardown: 步骤 3 中的图像 3,3
    • Removing the CD reader: Gently pull all 3 rubber grommets sideways, away from the CD reader.
    • Slide edge of ribbon cable connector towards ribbon cable to disengage.
    • Unplug the red, white, and blue plugs from the circuit board.
  4. Sony D-822K Car Discman Teardown: 步骤 4 中的图像 1,2 Sony D-822K Car Discman Teardown: 步骤 4 中的图像 2,2
    • Observation: This is the Hydro Suspension system...really.
  5. Sony D-822K Car Discman Teardown: 步骤 5 中的图像 1,3 Sony D-822K Car Discman Teardown: 步骤 5 中的图像 2,3 Sony D-822K Car Discman Teardown: 步骤 5 中的图像 3,3
    • Remove circuit board
    • Notice the dual-color light modules. (I temporarily connected the power to show off the lights)
  6. Sony D-822K Car Discman Teardown: 步骤 6 中的图像 1,1
    • Disconnect tailpiece, and power supply.
  7. Sony D-822K Car Discman Teardown: 步骤 7 中的图像 1,2 Sony D-822K Car Discman Teardown: 步骤 7 中的图像 2,2
    • Remote: Remove the 3 screws from the bottom. Pull apart.
    • The function buttons have a neat overlay design.
  8. Sony D-822K Car Discman Teardown: 步骤 8 中的图像 1,1
    • Completely disassembled. The illumination button was lost for two weeks after reassembling... but who uses amber lights anymore?
modem21
于10/09/09注册
84 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 25
总计 18,062
