跳转到主内容
修复你的物品
维修的权力
商店
在此拆机指南中使用的工具
简介
This is my first Teardown! Please don’t be negative about it. But, Constructive Criticism is welcome.
这个拆解是不是维修指南。 要维修你的的Sony Audio System RM-S100 Remote,请使用我们的维修手册
  1. On the back of the remote there will be a battery cover. Open it up. On the back of the remote there will be a battery cover. Open it up.
    • On the back of the remote there will be a battery cover. Open it up.
  2. See the little tab? Don't break the tab when you open it. That will make it un-close-able! Use your Spudger to open it up
    • See the little tab?
    • Don't break the tab when you open it. That will make it un-close-able!
    • Use your Spudger to open it up
    • Don’t snap your Spudger!
    • This is so incredibly hard to open. I recommend also using a 3.5mm Flat Head so you don’t snap your Spudger.
    • Voila! (Whatever that means...) Its open!
    • This is very hard to open without breaking the tab or your Spudger. The repairability score will take a hit.
  3. Let’s start by removing the red thing. You can remove it with your fingers. Now pull out the PCB. (It is best to pull by the springs.)
    • Let’s start by removing the red thing.
    • You can remove it with your fingers.
    • Now pull out the PCB. (It is best to pull by the springs.)
  4. Pull out the button pad. Now, pull out the spring.
    • Pull out the button pad.
    • Now, pull out the spring.
    • And thats it!
  5. A total of 7 parts. (I was expecting more.)
    • A total of 7 parts. (I was expecting more.)
    • I would give this a repairability score of 8 out of 10.
    • I almost Broke by Spudger =(
    • Insanely hard to open.
    • Easy to disassemble... once open.
    • No screws. (No Screws to lose! No need remember which screw goes where.)
    • Easy to assemble...unless the tab was broken.
Aiden
于2015年09月19日注册
14,813 信誉积分
创作了20篇指南
This is a great first teardown! =) Keep it up!
Sam Goldheart - 回复
Thanks! I would do more but I don’t have much junk to disassemble that I don’t need.
Aiden -
Hi @captainsnowball ,
FYI
voilà French exclamation - meaning “There it is!” or “There you are!”
The “red thing” in Step 3 is most probably an IR filter, to filter out visible light to improve IR operation
jayeff - 回复
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 5
过去的30天: 31
总计 2,328
