简介
深入探索来自 https://solar-breeze.com/ 的 Solar Breeze NX 自动泳池表面清洁器。
Solar Breeze NX 机器人是一款用于保持泳池表面清洁的酷炫工具!对其进行一些调整/定制可能会很有趣,所以让我们来看看里面有什么……
如果有人知道主板底部 6 针类白色接口的用途,以及应配合什么软件/协议使用,请分享一下。
目标:
#1 如果能在这里安装一个带有 WiFi 的 Raspberry Pi Zero,以便远程控制/与 SolarBreeze 的行为交互,那就太好了。虽然这会消耗更多的电池电量,但在南加州,太阳能输入相当稳定。也许我们可以安排“树莓派”每天只在短时间内激活一次,以防需要新的指令。
#2 我希望设置闪烁的蓝灯在晚上 11 点后熄灭(或完全关闭),这样它们造成的夜间光污染就会减少。
#3 我希望该设备能在午夜 12 点完全停止工作,或者在天黑后过 X 小时停止,这样夜晚会更加宁静。
有趣的梦想:
#1 安装摄像头,每天发送一张快照,以便在离开时查看水质/表面质量。
备注:
虽然螺丝是 6 角星形(T10 Torx 批头),但我能够使用 5/16 英寸内六角/Allen 扳手,且没有出现任何螺丝滑丝的情况。
看起来有 12 颗螺丝(似乎多于必要数量),为了将半柔性聚合物紧密且均匀地压在橡胶密封圈上,以防止水渗入。
技术规格: https://solar-breeze.com/technical-infor...
电池更换套件: https://solar-breeze.com/faq-page-1/
用户手册: https://solar-breeze.com/wp-content/uplo... ...目前这仅是一份“操作手册”,因为它并没有解释太多关于拥有/维修甚至更换电池的内容。
包含更多信息的官方 YouTube 播放列表:如何修理您的 SolarBreeze
你所需要的
15指南评论
Pretty good details, and suggestions of improvement, I also would like to have that! Do you have more pictures and details? How about the motors how good are they? how much voltage for the motors? Just curious... thanks!
They just started advertising the “NX2” on Amazon. Not sure I’ll buy another Solar Breeze. Mine only lasted about a year when the rear wheels stopped turning. Solar Breeze did send me a replacement gear set for the rear but the unit seems to always be in error mode. I’d love to figure out how to replace the main controller board with a Pi. I’m pretty sure the motors are like servos in that they give feedback. If I manually spin my rear paddle, the error light goes out and it functions as normal for another minute. So, my wish list:
1) Pi based controller
2) Wifi/BT interface
3) GPS avoidance (stop getting stuck under my dive rock
4) high wind avoidance (stop getting stuck downwind, just shutdown and wait)
5) Alert me if you are removed from the pool (theft deterent? Maybe tie into my house alarm?)
6) Repairable/replaceable parts - I hate that society has a throw-it-away attitude.
Same issue as Tim here. I think he means the front wheels. I’ve done a tear down and there are two little motors on the front wheels. The motors go out pretty easily, I replaced the unit twice while it was still under warranty. Has anyone replaced or found a replacement motor for the front wheels?
Drew 272727 - 回复 分享
