跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Sky TV Remote,请使用我们的维修手册
  1. Sky TV Remote Teardown, Sky TV Remote Teardown: 步骤 1 中的图像 1,3 Sky TV Remote Teardown, Sky TV Remote Teardown: 步骤 1 中的图像 2,3 Sky TV Remote Teardown, Sky TV Remote Teardown: 步骤 1 中的图像 3,3
    • This is it. Well, this is it in a functional state.
    • Remove the batteries before starting!
  2. Sky TV Remote Teardown: 步骤 2 中的图像 1,3 Sky TV Remote Teardown: 步骤 2 中的图像 2,3 Sky TV Remote Teardown: 步骤 2 中的图像 3,3
    • Use a Philips head screwdriver to remove this screw
    • Use a spudger to unlock all the tabs around the sides, start at the bottom
    • Work your way all the way around the remote, this is flippin' tricky.
    • Brute force is compulsory.
  3. Sky TV Remote Teardown: 步骤 3 中的图像 1,3 Sky TV Remote Teardown: 步骤 3 中的图像 2,3 Sky TV Remote Teardown: 步骤 3 中的图像 3,3
    • After all the tabs are off, the body should just fall away leaving the buttons, the circuit board, the case and the black infra-red bit at the end.
    • Ta-daa!
3条评论
On early models theres a second screw under the black infa red filter. If it doesnt come apart as above, ther black filter is held on by two tabs. On the battery compartment side, the black plastic nearest the battery, wedge a small screwdriver between the body and the pastic and the filter should slide away revealing a second screw!
tim - 回复
How do I clean? Buttons not making electrical connection. New remots don't recognize my TV.
Ronald Welemin - 回复
Also, is there a product that I can put on the connection buttons to improve contact?
Ronald Welemin - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 27
过去 30 天: 216
总计 17,037
