跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
First attempt at a tear down of Seagates 3TB External Drive.
这个拆解是不是维修指南。 要维修你的的External Storage,请使用我们的维修手册
  1. Start at the plain end (the opposite side from the power jack) with the spudger. Carefully pry slightly up and away.
    • Start at the plain end (the opposite side from the power jack) with the spudger. Carefully pry slightly up and away.
    • Once you have the end opened up, use the credit card to hold it open.
    • When you have the entire end separated, carefully pry the sides out and away along the adjoining two sides, working your way towards the end with the power jack. Save that end for last, it should lift away when you're done with the other sides.
  2. Work around the drive, ends first then the sides to open it This is really challenging and I did end up breaking some of the clips. Its pretty hard to tear apart. This is really challenging and I did end up breaking some of the clips. Its pretty hard to tear apart.
    • Work around the drive, ends first then the sides to open it
    • This is really challenging and I did end up breaking some of the clips. Its pretty hard to tear apart.
  3. LCD iPhone 屏幕维修套装
    预算选项,涵盖在我们的终身保修中。
    购买套装
    LCD iPhone 屏幕维修套装
    削减维修成本,而不是质量。
    购买套装
  4. Gently pull the sides slightly and the drive will lift out
    • Gently pull the sides slightly and the drive will lift out
  5. Pull the rubber screw covers off, these are mounted with a little glue and came off easily Remove all four screws with the philips screwdriver Remove all four screws with the philips screwdriver
    • Pull the rubber screw covers off, these are mounted with a little glue and came off easily
    • Remove all four screws with the philips screwdriver
  6. Slide drive out of metal caddy (do not lift) You will now have a SATA Hard Drive and the caddy separate You will now have a SATA Hard Drive and the caddy separate
    • Slide drive out of metal caddy (do not lift)
    • You will now have a SATA Hard Drive and the caddy separate
  7. From the bottom of the caddy there are two black screws With the Philips screwdriver you can remove these Pull the circuit board gently and evenly to remove it
    • From the bottom of the caddy there are two black screws
    • With the Philips screwdriver you can remove these
    • Pull the circuit board gently and evenly to remove it
Edd
于2013年04月08日注册
511 信誉积分
创作了2篇指南
if i add a different adapter that doesnt require power, will the drive still work?
sulz - 回复
Does anyone know what to do if the Data port does not work ?
remus lungeanu - 回复
添加评论
浏览统计数据:
过去的24小时: 11
过去的7天: 84
过去的30天: 288
总计 49,348
