跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Scrabble Flash,请使用我们的维修手册
  1. Scrabble Flash Teardown, Scrabble Flash Teardown: 步骤 1 中的图像 1,2 Scrabble Flash Teardown, Scrabble Flash Teardown: 步骤 1 中的图像 2,2
    • This is a small game but still surprisingly fun... but not enough to keep me from tearing it down!
  2. Scrabble Flash Teardown, Remove the Back: 步骤 2 中的图像 1,1
    • This was held together by only one Phillips screw. So far so good.
    • Battery was a CR2032, which seems to be a common choice for this type/size of device
    • The speaker is in the bottom-right hand corner, with the reset switch above it.
  3. Scrabble Flash Teardown: 步骤 3 中的图像 1,1
    • Two screws and a clip held the two halves of the case together, with two more keeping the speaker in place. Also, it looks like the only screws used in this device are Phillips! Great!
  4. Scrabble Flash Teardown, On to the Motherboard: 步骤 4 中的图像 1,2 Scrabble Flash Teardown, On to the Motherboard: 步骤 4 中的图像 2,2
    • On the back side of the motherboard, we see the battery contacts in the upper-left hand corner, and the four screws that hold the display to the front.
  5. Scrabble Flash Teardown, Display Removal: 步骤 5 中的图像 1,3 Scrabble Flash Teardown, Display Removal: 步骤 5 中的图像 2,3 Scrabble Flash Teardown, Display Removal: 步骤 5 中的图像 3,3
    • After removing three of the screws, I found that the one holding down the bottom-left corner of the display was stripped, forcing me to cut and rotate the corner away.
    • After that however, it just dropped right off.
    • The display is just a simple black and white LCD.
  6. Scrabble Flash Teardown, Done!: 步骤 6 中的图像 1,1
    • And here we are, all done!
Isaiah Payton
于12/29/16注册
133 声望
撰写一个指南
2条评论
Very cool, great teardown!!
Kevin Stuckey - 回复
Mine has a broken infrared thingy. Any idea how to/if it's fixable? I hope someone reads this :s
Yemir 2 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 21
总计 2,009
