跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Scotch TL901,请使用我们的维修手册
  1. Scotch TL901 Teardown, The Laminator: 步骤 1 中的图像 1,1
    • The Scotch TL901 Laminator
  2. Scotch TL901 Teardown, Unscrewing the Case: 步骤 2 中的图像 1,1
    • Using a small Phillips screwdriver, remove the screws from the bottom of the plastic case.
    • Rubber feet in the four corners must be removed first to gain access to the screws underneath. A sticker may also be covering the middle screw on the left.
  3. Scotch TL901 Teardown, The Opened Laminator: 步骤 3 中的图像 1,1
    • Pull off the silver plastic cover and gain access to the internal components.
    • The rollers, motor, circuit board, and LEDs are all visible now.
  4. Scotch TL901 Teardown, The Circuit Board: 步骤 4 中的图像 1,1
    • First unplug all three wire headers connected to the circuit board.
    • Unscrew the two screws holding down the circuit board by its corners and remove the board from the laminator.
  5. Scotch TL901 Teardown, The Spring: 步骤 5 中的图像 1,1
    • Unhook the spring from the plastic surrounding the motor.
  6. Scotch TL901 Teardown, The Rollers: 步骤 6 中的图像 1,1
    • Hold the roller enclosure from both sides, indicated by the markers, and pull upwards and slightly out.
    • Free access to the motor and rollers is now possible.
  7. Scotch TL901 Teardown, The Motor: 步骤 7 中的图像 1,1
    • Remove the motor from the rollers by unscrewing the three screws holding them together.
  8. Scotch TL901 Teardown, The Sensor: 步骤 8 中的图像 1,1
    • Remove the sensor from the roller enclosure by unscrewing the two spring-loaded screws.
  9. Scotch TL901 Teardown, The Other Side: 步骤 9 中的图像 1,1
    • Unscrew the two screws and the bar on the other.
  10. Scotch TL901 Teardown, The Gears: 步骤 10 中的图像 1,1
    • Pull the black washers sideways off the metal rod of the roller.
    • Pull the gears off.
  11. Scotch TL901 Teardown, The Disassembled Rollers: 步骤 11 中的图像 1,2 Scotch TL901 Teardown, The Disassembled Rollers: 步骤 11 中的图像 2,2
    • With the gears off, the plastic panel falls off and the rollers come out of the enclosure.
    • The laminator is now disassembled.
Calvin Xu
于04/18/13注册
202 声望
撰写一个指南
团队
F14BraunReverseEng F14BraunReverseEng 的会员
Community
2 名成员
创作了8篇指南
16条评论
Why is the screw on the left side so hard to get out?
Teri L Geist - 回复
Thank you..
Putting it back together is more of a challenge.
Frank - 回复
You're right Frank. For me, getting it to stay together after the tear down and reassembly required superglue and two extra screws. ;) But at least it's working again. Thanks for the great instructions.
pjcall975 - 回复
Thank you! Just needed to open and remove a jam. Followed your guide and all is well.
KQuinn
Kate Quinn - 回复
Thank you for posting these instructions. I was able to remove a quarter that got trapped inside.
seanretzloff - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 28
过去 30 天: 130
总计 29,250
