跳转到主内容
修复你的物品
维修的权力
商店
在此拆机指南中使用的工具
简介
This guide exist because I want to clean the fans and heatsinks, I will show to you photos of the best order to stripdown the GPU.
If you want to clean the heatsink or fans you will need thermal paste because it needs a complete teardown to release the fans.
这个拆解是不是维修指南。 要维修你的的Video Card,请使用我们的维修手册
  1. To strip down the GPU you will need a Phillips screwdriver To strip down the GPU you will need a Phillips screwdriver To strip down the GPU you will need a Phillips screwdriver
    • To strip down the GPU you will need a Phillips screwdriver
  2. Disconnect the fans and the light connector Disconnect the fans and the light connector
    • Disconnect the fans and the light connector
  3. Remove the pair of screw that join the heatsink to the output base. Note! This pair of screws is unique to this join. Keep them seperate from other screws.
    • Remove the pair of screw that join the heatsink to the output base.
    • Note! This pair of screws is unique to this join. Keep them seperate from other screws.
  4. Remove 11 screws, those (+ the next 4 screws) work joining the heapsink+fans group to the gpu Note: Ignore 2 empty holes
    • Remove 11 screws, those (+ the next 4 screws) work joining the heapsink+fans group to the gpu
    • Note: Ignore 2 empty holes
  5. Now release 4 of the screws that hold the GPU Core to the heatsink Note this is the clean, thermal paste ready photo This is the 3 years dirty one
    • Now release 4 of the screws that hold the GPU Core to the heatsink
    • Note this is the clean, thermal paste ready photo
    • This is the 3 years dirty one
  6. Remove 4 screws  to separate the fans of the heatsink Note these screws are pointed tip for plastic
    • Remove 4 screws to separate the fans of the heatsink
    • Note these screws are pointed tip for plastic
    • At this point you'll release the heatsink is not very clean
  7. This is good time to clean the heatsink if it's dirty This is good time to clean the heatsink if it's dirty This is good time to clean the heatsink if it's dirty
    • This is good time to clean the heatsink if it's dirty
  8. Remove 3 screws per side (6 screws in total) to release the 2 metal plates Remove 3 screws per side (6 screws in total) to release the 2 metal plates Remove 3 screws per side (6 screws in total) to release the 2 metal plates
    • Remove 3 screws per side (6 screws in total) to release the 2 metal plates
  9. Remove 3 screws (per fan 9 in total) to release each fan Remove 2 screws that holds the light and fan wires unplug and remove the light
    • Remove 3 screws (per fan 9 in total) to release each fan
    • Remove 2 screws that holds the light and fan wires
    • unplug and remove the light
  10. At this point you can easy remove the fans Note: the one with the shorter cable and  4 wires is the center one (for the GPU core) the one with double 4 wire connector is the nearest to the gpu outputs
    • At this point you can easy remove the fans
    • Note: the one with the shorter cable and 4 wires is the center one (for the GPU core)
    • the one with double 4 wire connector is the nearest to the gpu outputs
  11. At this point you can easy clean your fans, the fan support (it's plastic) and the plates At this point you can easy clean your fans, the fan support (it's plastic) and the plates
    • At this point you can easy clean your fans, the fan support (it's plastic) and the plates
  12. when you're joining the heatsink (plus the fan support), I recommend you put the block on the edge of the table for optimal position Remmember to clean the old thermal paste and replace with a new coat Remmember to clean the old thermal paste and replace with a new coat
    • when you're joining the heatsink (plus the fan support), I recommend you put the block on the edge of the table for optimal position
    • Remmember to clean the old thermal paste and replace with a new coat
dfoxpro
于2012年06月09日注册
151 信誉积分
撰写一个指南
I have the same card and I find your guide very useful. My problem is that the last fan (at the end where there're the power connectors) only starts spinning at 80%. Do you have any idea how can I fix it?
Péter Friedrich - 回复
Is that what is going on with my EVGA Geforce GTX 970 4gb when it looks like just one of the 2 fans are spinning? I'll have to Google it and see, because I was about to go ahead and do this. Not because it overheats, as 2k scaled to 4k resolution benchmarking never takes it over 79c, maybe touching 80c without throttling. I'm a moon, but I don't think that is hot. Seen 100c/213f on my Lenovo, but it was an i7 processor with switchable graphics from Intel to AMD R9 GPU. And without good ventilation from beneath, it was easy to overheat… was scary!
Anyways, thanks for the likely answer to a question I've had.
Brick Banana - 回复
I had a similar issue with my RX580 right out of the box (damaged in shipping) because the shroud was bent slightly so that the fan was catching. You might want to mess around a bit and see if the fan can spin freely. Best of luck!
Reed Crosby -
添加评论
浏览统计数据:
过去的24小时: 8
过去的7天: 25
过去的30天: 125
总计 7,010
