跳转到主内容
修复你的物品
维修的权力
配件 & 工具
在此拆机指南中使用的工具
简介
Follow the steps in this guide in order to gain access to components found inside the device which most often require repair of replacement.
这个拆解是不是维修指南。 要维修你的的Sandisk Sansa m230 Series mp3 player,请使用我们的维修手册
  1. Remove the battery compartment cover.
    • Remove the battery compartment cover.
    • Remove the battery.
  2. Locate and remove the screw next to the battery compartment lid.
    • Locate and remove the screw next to the battery compartment lid.
  3. LCD iPhone 屏幕维修套装
    预算选项,涵盖在我们的终身保修中。
    购买套装
    LCD iPhone 屏幕维修套装
    削减维修成本,而不是质量。
    购买套装
  4. Locate the interlocking pegs along the seam of the device's casings.
    • Locate the interlocking pegs along the seam of the device's casings.
    • Gently pry the pegs apart one at a time, working your way around the case.
    • Be careful when prying apart the pegs: they are made of plastic and may break.
  5. The battery contact springs may prevent the case from separating.
    • The battery contact springs may prevent the case from separating.
    • Push the battery contact springs down through the hole in the case.
  6. The casing protecting the USB and headphone jacks must be removed.
    • The casing protecting the USB and headphone jacks must be removed.
    • Locate and gently pry apart the two interlocking clips holding it in place.
    • The outer casings may now be removed and the MP3 player should separate.
  7. You now have access to all components found on the inside of the device!
    • You now have access to all components found on the inside of the device!
James Thorne
于2013年11月05日注册
638 信誉积分
创作了6篇指南
团队
UMass Dartmouth, Team 1-8, Shastany Fall 2013 UMass Dartmouth, Team 1-8, Shastany Fall 2013 的会员
UMASSD-SHASTANY-F13S1G8
3 名成员
创作了6篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 4
过去的30天: 8
总计 2,221
