这个拆解是不是维修指南。 要维修你的的Samsung SGH-C450,请使用我们的维修手册
  1. Remove the battery cover, battery and SIM Card.
    • Remove the battery cover, battery and SIM Card.
  2. Remove these screws.
    • Remove these screws.
  3. Insert yout flathead screwdriver or opening here and go around the device
    • Insert yout flathead screwdriver or opening here and go around the device
    • Gently pry open the case.
  4. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  5. Once the case is removed you can see the PCB.
    • Once the case is removed you can see the PCB.
    • NXP OM6357EL4 ARM CPU
    • SPANSION Flash Memory
    • NXP CF50600 battery and power supply controller
    • SIM Card slot
    • EMI Shield
    • Battery Contacts
  6. To get the other side of the PCB, pull up the edges of the PCB with a flathead screwdriver.
    • To get the other side of the PCB, pull up the edges of the PCB with a flathead screwdriver.
    • To remove the EMI shield on the other side, remove these screws
  7. The IC's under the EMI shield.
    • The IC's under the EMI shield.
    • Skyworks SKY77518 Dual-Band GSM/GPRS Module
  8. Finished!
    • Finished!
Bryan
于2012年10月27日注册
690 信誉积分
创作了5篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 8
总计 1,475
