跳转到主内容
本拆机指南正在进行中 – 定期刷新以看到更新!
你所需要的
  1. Samsung SCH-U340 Teardown, Samsung SCH-U340 Teardown: 步骤 1 中的图像 1,1
    • The U340's outer casing is held in place through a combination of screws and tabs. The screws are hidden under plastic plugs, which will need to be removed.
  2. Samsung SCH-U340 Teardown: 步骤 2 中的图像 1,1
    • After these plugs are pulled out, remove the two screws located under them. These screws are very small, so be sure to keep them safe.
  3. Samsung SCH-U340 Teardown: 步骤 3 中的图像 1,1
    • The only thing keeping the top part of the casing on now are seven tabs--one large tab (marked in red) and six smaller tabs (marked in yellow). To remove the casing, first start by removing the big tab.
  4. Samsung SCH-U340 Teardown: 步骤 4 中的图像 1,1
    • Now remove the smaller tabs, doing the tabs marked in red last. After the tabs have been removed, carefully peel the outer cover off completely.
  5. Samsung SCH-U340 Teardown: 步骤 5 中的图像 1,1
    • Removing the bottom cover is a much simpler task. After removing the four screws marked in the picture, simply peel the back cover off.
Anish Sambamurthy
于02/11/10注册
29 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 12
总计 1,007
