拆解
This is a teardown of the Samsung SCH-8500.
这个拆解是不是维修指南。 要维修你的的Samsung SCH-8500,请使用我们的维修手册。
The phone we are taking apart today is the Samsung SCH-8500
Press on black button next to battery and use metal spuger or other pointy object to pop the battery of the back.
Remove 4 0.6mm screws with a T6 Screwdriver.
Remove the little rubber piece.
Then gently lift off back case.
Unscrew the antenna from back case.
Pry off the 2 covers on the display.
Remove the 2 0.3mm screws from display
Pry the speaker cover off display, to reveal 2 screws.
Remove 2 0.3mm screws.
Use a case opening tool and pry the case of the display.
Pry the display, speakers, and main board of of phone
Take off the keys
Voila! You're done.
于03/13/13注册
131 声望
撰写一个指南
徽章: 3
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 6
总计 881
