跳转到主内容
你所需要的
本篇指南是分解流程而非维修指南。 如果您要维修您的Samsung Galaxy S II,应参考我们的维修指南
  1. Samsung Galaxy S II Teardown, Samsung Galaxy S II Teardown: 步骤 1 中的图像 1,1
    • Step 1- Use an opening tool, or your fingernail into the opening at the top near the headphone jack.
    • Use the tool or your fingernail to pry the opening open.
  2. Samsung Galaxy S II Teardown: 步骤 2 中的图像 1,2 Samsung Galaxy S II Teardown: 步骤 2 中的图像 2,2
    • If an microSD card is inserted, use the flat end of a spudger and push it until you hear a click sound and it will release right after.
    • Once you reassemble the midframe, place the microSD card back into it's slot
    • Do the exact same thing with your battery and do not damage the battery in any way.
  3. Samsung Galaxy S II Teardown: 步骤 3 中的图像 1,3 Samsung Galaxy S II Teardown: 步骤 3 中的图像 2,3 Samsung Galaxy S II Teardown: 步骤 3 中的图像 3,3
    • Remove all six pf the 4.0 mm Philips #00 screws securing the back of the device to the front
  4. Samsung Galaxy S II Teardown: 步骤 4 中的图像 1,1
    • Pry the midframe all around the device to carefully remove it
    • If you do not pry throughout the whole device, the midframe will be very hard to remove
    • A plastic tool opener would be better and it will not damage the phone.
  5. Samsung Galaxy S II Teardown: 步骤 5 中的图像 1,2 Samsung Galaxy S II Teardown: 步骤 5 中的图像 2,2
    • Remove the midframe carefully
    • If your previous midframe was broken, place a new one. When you hear a click sound throughout the device, you know you have snapped it into place
Vanessa Cardenas
于11/01/16注册
241 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 11
总计 1,208
