拆解
This is a Teardown of my old broken Samsung Galaxy Pocket (GT-S5300)
这个拆解是不是维修指南。 要维修你的的Samsung Galaxy Pocket (GT-S5300),请使用我们的维修手册。
Remove the battery cover
Then remove the battery
Remove all 4 screws
Slide a guitar pick between the sliver bezel and the rear of the phone
Slide it all the way around until the rear is loosened from the logic board and screen
Remove LCD connector
Remove logic board from screen by lifting the logic board up and removing the digitizer connector
Remove the 5 screws to remove the shield
Remove what seems to be the antenna from the logic board
Slide guitar pick between the digitizer and lcd
Make sure not to get under the black adhesive on the back be the digitizer
At the top of the digitizer there is a circuit be careful up there
Então essa é a minha desmontagem para o bolso da galáxia Samsung (GT-S5300)
与3其他贡献者
于02/08/14注册
370 声望
撰写一个指南
徽章: 3
Parabéns excelente trabalho…
marciel.d.avila - 2021年5月24日 回复
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 13,213
