跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Rubik's Cube,请使用我们的维修手册
  1. Rubik's Cube Teardown, Rubik's Cube Teardown: 步骤 1 中的图像 1,3 Rubik's Cube Teardown, Rubik's Cube Teardown: 步骤 1 中的图像 2,3 Rubik's Cube Teardown, Rubik's Cube Teardown: 步骤 1 中的图像 3,3
    • Turn the top row so that each corner is roughly halfway between the sides
    • Push the pieces up until they pop out of the cube, then, slide the rest out
    • Repeat this process until you clear the level
  2. Rubik's Cube Teardown: 步骤 2 中的图像 1,2 Rubik's Cube Teardown: 步骤 2 中的图像 2,2
    • You should be able to just directly pull out the rest of the blocks, like so
    • And there you have it!
    • You'll have the center piece, with the six centers of the six sides, the turning mechanism
  3. Rubik's Cube Teardown: 步骤 3 中的图像 1,2 Rubik's Cube Teardown: 步骤 3 中的图像 2,2
    • To reassemble, snap all the pieces back into place, and try not to rotate the faces.
    • It helps to start with the middle pieces first
    • Don't be afraid to use force!
    • Once you have the middle pieces in it's pretty simple to just push in the corner pieces
    • Again- don't be afraid to use force!
rab777hp
于11/17/09注册
20,333 声望
创作了3篇指南
团队
OPEN OPEN 的会员
Community
82 名成员
创作了25篇指南
6条评论
I hated this thing. I disassembled mine with a .22 hollow point at 100 yards. Yes, It felt great!
mpias - 回复
lol don’t blame you, can’t stand the thing
Luke -
that method just broke my rubiks my cube.. thanks anyway
hamzamagdy888 - 回复
my middle peices came out cant fix it
jax - 回复
can someone tell me how to fix it
jax - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 17
过去 30 天: 44
总计 24,567
