简介
I've found a vacuum in my utility room. Since I almost never use it, I thought it was a good idea to see how it works... So let's go!!
这个拆解是不是维修指南。 要维修你的的Rowenta AC6221,请使用我们的维修手册。
The 4.8 Rowenta vacuum can be used for a variety of purposes.
It is charged through its pedestal. The power of the pedestal is:
Input: 230V - 50 Hz - 7W (AC)
Output: 7.5V - 300 mA (DC)
This vacuum has several parts:
The tip
The reservoir which holds the dust and debris
The engine (4.8V)
The pedestal
The power supply
From top to bottom, the reservoir contains 3 parts: the housing, container, and filter.
The wires of the vacuum are now visible.
The wires connect the charger light, switch,engine, and power wires.
The green box labels the engine.
The orange box labels one of the four batteries (4*1.2V)
The top of the circuit board contains components including capacitors, resistors, wires, and a chip.
The bottom side shows the tracks that connect the components.
Remove the screw securing the handle with a screwdriver.
Open the handle to see the inside using the flat screwdriver.
Warning: The handle is difficult to open
Warning: In this procedure, the handle was not opened to keep the vacuum intact.
At the bottom of the pedestal, remove the 4 rubber pieces.
Note: This step provides access to 4 Philips screws.
Remove screws using a screwdriver.
Inside the pedestal, the power cable separates into 2 wires. Each wire is connected to a conductive piece.
This completes the vacum cleaner teardown
嵌入本指南
选择尺寸并复制下面的代码嵌入本指南,为你网站/论坛的一个小插件。
预览
