跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Rogue G10,请使用我们的维修手册
  1. Rogue G10 Teardown, Rogue G10 Teardown: 步骤 1 中的图像 1,3 Rogue G10 Teardown, Rogue G10 Teardown: 步骤 1 中的图像 2,3 Rogue G10 Teardown, Rogue G10 Teardown: 步骤 1 中的图像 3,3
    • Here is the front view of the Rogue G10 amp.
    • Back side shows 4 Phillips head screws that need to be removed.
    • Here are the 4 #6x1" screws
  2. Rogue G10 Teardown: 步骤 2 中的图像 1,3 Rogue G10 Teardown: 步骤 2 中的图像 2,3 Rogue G10 Teardown: 步骤 2 中的图像 3,3
    • Use a small screwdriver or other small suitable prying instrument to remove the back cover.
    • With the back cover removed the speaker and amp become visible.
    • Remove the 2 Phillips head screws from the carrying handle. These two screws also attach the amp to the onside of the case.
  3. Rogue G10 Teardown: 步骤 3 中的图像 1,3 Rogue G10 Teardown: 步骤 3 中的图像 2,3 Rogue G10 Teardown: 步骤 3 中的图像 3,3
    • Here are the two screws from the handle. They are 1/8"x1 1/4"
    • Remove the 16 screws from the plastic corners. These corners serve no purpose other than decoration.
    • There are 4 rubber feet on the bottom of the amp.
  4. Rogue G10 Teardown: 步骤 4 中的图像 1,3 Rogue G10 Teardown: 步骤 4 中的图像 2,3 Rogue G10 Teardown: 步骤 4 中的图像 3,3
    • This shows the corners with the screws removed.
    • Remove the rubber feet by removing the Phillips head screws.
    • On the left and right side of the amp is a Phillips head screw, located 1/3 down from the top and to the front. These two screws hold the front panel to which the speaker is attached. Remove those.
  5. Rogue G10 Teardown: 步骤 5 中的图像 1,3 Rogue G10 Teardown: 步骤 5 中的图像 2,3 Rogue G10 Teardown: 步骤 5 中的图像 3,3
    • Here is the one on the right side, same location.
    • Remove it as well
    • With those two screws removed, the front panel which houses the speaker, can be simply removed
  6. Rogue G10 Teardown: 步骤 6 中的图像 1,3 Rogue G10 Teardown: 步骤 6 中的图像 2,3 Rogue G10 Teardown: 步骤 6 中的图像 3,3
    • remove the front panel and place aside.
    • With the front panel removed, the amp will now simply lift out as well
    • Here is the amp totally disassembled. Straight forward job. No glue, no hidden screws.
oldturkey03
于09/29/10注册
782,216 声望
创作了119篇指南
团队
Global Fixers Global Fixers 的会员
Community
33 名成员
创作了537篇指南
4条评论
Do these models have tubes in them?
Camron Buxton - 回复
No, they do not. Strictly solid state
oldturkey03 -
Thank you so much
Camron Buxton - 回复
What may be causing the scratchy sound only when playing on my G10? Tried multiple cables and cleaned the input with electrical contact cleaner and there was no change. If I run a cable from the Phones jack to my computer input then the noise is not there.
Brian Day - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 11
总计 3,121
