跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Rockford Fosagte P300-12,请使用我们的维修手册
  1. Rockford Fosgate P300-12 Teardown, Rockford Fosgate P300-12 Teardown: 步骤 1 中的图像 1,1
    • Front view
  2. Rockford Fosgate P300-12 Teardown: 步骤 2 中的图像 1,3 Rockford Fosgate P300-12 Teardown: 步骤 2 中的图像 2,3 Rockford Fosgate P300-12 Teardown: 步骤 2 中的图像 3,3
    • Remove the 8 coarse thread wood screws and gently pry the plate out
  3. Rockford Fosgate P300-12 Teardown: 步骤 3 中的图像 1,2 Rockford Fosgate P300-12 Teardown: 步骤 3 中的图像 2,2
    • Carefully remove the 3 knobs and the 1 screw between the 2 10A fuses. then the plastic face should pop off
  4. Rockford Fosgate P300-12 Teardown: 步骤 4 中的图像 1,3 Rockford Fosgate P300-12 Teardown: 步骤 4 中的图像 2,3 Rockford Fosgate P300-12 Teardown: 步骤 4 中的图像 3,3
    • Crossover / Gain
    • Power Supply and output FET's
    • Power Supply Transformer
    • Output Filters
    • The 2 boards are held together by 4 screws on the edges of the PCB, gently pull them apart, they will only be held together by pin headers. Here you can see the 2 output filters and the power supply step up transformer
    • The board with the FEMALE pin headers is the front board with the plugs on it. the crossover network consists of JRC 4850's
  5. Rockford Fosgate P300-12 Teardown: 步骤 5 中的图像 1,1
    • There are 4 of these "GA7E1S" FET's that i cant find any info on. i would assume by looking at the boards that 2 are the power supply and the other 2 are the outputs
    • There are NO heatsinks anywhere in this unit which i find amazing. but the FETS most likely use the massive copper planes on the board as the heatsink
  6. Rockford Fosgate P300-12 Teardown: 步骤 6 中的图像 1,2 Rockford Fosgate P300-12 Teardown: 步骤 6 中的图像 2,2
    • More jelly bean logic around the board
  7. Rockford Fosgate P300-12 Teardown: 步骤 7 中的图像 1,2 Rockford Fosgate P300-12 Teardown: 步骤 7 中的图像 2,2
    • The custom 12" driver. it appears to be a DVC driver, but it just a SVC with 2 pairs of leads going to it
bassblaster505
于01/25/17注册
539 声望
创作了4篇指南
23条评论
Nice, if you can do one on pulling the sub out that would be great. I think it might be glued in.
Cometa Soulstar - 回复
I have the 10” version of this sub but believe the amp is identical. I’d like to steal the amp from this to use in a new enclosure. Any idea how many ohms this could drive?
Ian Pitts - 回复
Im not sure, when i did this teardown i never thought about doing an ohms test on the driver. it might be a 2 ohm driver, but if you have the 10”, pop the plate amp out and stick a meter on the driver lol
bassblaster505 -
I have a p300-12 , but the box shape is all wrong for my ‘07 FJ. What obstacles do you see after the teardown for transplanting the amp and sub into a custom fit box? Thanks in advance!
Jason Todd - 回复
i dont see any issues with that idea. just when you get a new box get one thats similar in volume as the original and also sealed as i have no idea how the driver would perform in a vented enclosure. just keep the original rockford box so if you decide to sell it down the line you can reinstall it
bassblaster505 -
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 23
过去 30 天: 74
总计 6,214
