跳转到主内容
修复你的物品
维修的权力
商店
简介
Robie the Banker is an electronic coin bank that was sold by Radio Shack during the 1980s. It was first created by Japanese toy company Tomy (and named Mr. Money). Radio Shack bought distribution rights in the US and renamed it Robie.
It made for a popular Christmas gift for kids, and gave them a bit of an incentive to start saving their spare change, as Robie dances and licks his lips after eating a coin.
这个拆解是不是维修指南。 要维修你的的Toy,请使用我们的维修手册
  1. It may look slightly creepy, but Robie taught me about money at a very young age, and incentivized me to save my spare change. Sold in the US by Radio Shack in the 80s and 90s,  this gift from my Grandma was a huge hit at our family's Christmas gathering.
    • It may look slightly creepy, but Robie taught me about money at a very young age, and incentivized me to save my spare change.
    • Sold in the US by Radio Shack in the 80s and 90s, this gift from my Grandma was a huge hit at our family's Christmas gathering.
    • But enough reminiscing! Let's tear this thing down to see what makes Robie tick.
    • Using our handy-dandy Spudger, we perform a craniotomy on Robie by carefully prying off the top plastic cover in order to get at the screws underneath.
  2. Lucky for us, Robie is held together with standard Phillips #2 screws throughout, and there are three of them holding his head cover in place. Lucky for us, Robie is held together with standard Phillips #2 screws throughout, and there are three of them holding his head cover in place. Lucky for us, Robie is held together with standard Phillips #2 screws throughout, and there are three of them holding his head cover in place.
    • Lucky for us, Robie is held together with standard Phillips #2 screws throughout, and there are three of them holding his head cover in place.
  3. Well, this is terrifying. Quick! Let's move on to the next step before we get nightmares!
    • Well, this is terrifying. Quick! Let's move on to the next step before we get nightmares!
  4. Robie's eyes are loosely held in place, so let's remove them before they fall out accidentally and roll under the desk. Robie's eyes are loosely held in place, so let's remove them before they fall out accidentally and roll under the desk. Robie's eyes are loosely held in place, so let's remove them before they fall out accidentally and roll under the desk.
    • Robie's eyes are loosely held in place, so let's remove them before they fall out accidentally and roll under the desk.
  5. Just two screws hold Robie's head to its body. After removing those, we can carefully lift the head up and set it off to the side. These two screws are still accessible without removing Robie's head cover and eyes. So you can detach the entire head assembly in one piece if you need to get inside more  quickly. These two screws are still accessible without removing Robie's head cover and eyes. So you can detach the entire head assembly in one piece if you need to get inside more  quickly.
    • Just two screws hold Robie's head to its body. After removing those, we can carefully lift the head up and set it off to the side.
    • These two screws are still accessible without removing Robie's head cover and eyes. So you can detach the entire head assembly in one piece if you need to get inside more quickly.
  6. Before we can go any further, we need to remove Robie's feet covers so we have more room when removing his body. The power switch is located in his left foot—nothing in his right.
    • Before we can go any further, we need to remove Robie's feet covers so we have more room when removing his body.
    • The power switch is located in his left foot—nothing in his right.
    • Robie's body is split into two halves, which are held in place by clips and tape.
    • Using some tweezers, removing the tape is a piece of cake.
  7. The clips are fairly weak (hence the tape, most likely), so separating the body enclosure is also a piece of cake. The clips are fairly weak (hence the tape, most likely), so separating the body enclosure is also a piece of cake. The clips are fairly weak (hence the tape, most likely), so separating the body enclosure is also a piece of cake.
    • The clips are fairly weak (hence the tape, most likely), so separating the body enclosure is also a piece of cake.
  8. The motor assembly is attached to the base with three screws—two in the front and one in the back.
    • The motor assembly is attached to the base with three screws—two in the front and one in the back.
    • Unfortunately, the battery contacts are soldered to the motor assembly, so any repairs or replacement of the motor will require a soldering iron and some basic soldering skills to remove it entirely.
    • But once those two wires are removed, separating the motor assembly from the base is a cinch.
  9. The motor assembly is filled with all sorts of gears and servo motors that make Robie move. If needed, you can open up the enclosure to gain access to these components by removing four screws, but we feel like this is a good stopping point for this teardown.
    • The motor assembly is filled with all sorts of gears and servo motors that make Robie move.
    • If needed, you can open up the enclosure to gain access to these components by removing four screws, but we feel like this is a good stopping point for this teardown.
  10. Robie handled his teardown with aplomb! He'll be put back together so he can continue to eat coins in peace.
    • Robie handled his teardown with aplomb! He'll be put back together so he can continue to eat coins in peace.
I love to take things apart too. Sometimes I even fix things that are not broken…
Brett E. Chmura - 回复
Fun to see a relatively low-tech teardown. But I didn’t learn anything about how the innards actually make Robie move. Should I expect that from a teardown?
John Wackman - 回复
添加评论
浏览统计数据:
过去的24小时: 7
过去的7天: 49
过去的30天: 139
总计 2,230
