简介
Teardown of the Rippa RA903B Six Axis PS4 Controller.
你所需要的
There 6 total screws holding the outside shell of the controller together 4 of which are visible.
Remove the 4 visible screws as highlighted in the images. 2 on the rear and 1 on the bottom of each grip, totaling 2 screws from the left and right grip.
The left and right grips come off similar to the Nintendo Switch Pro controller, the direction you should pull is shown with the white arrow.
Note: Keep your screws mostly organised. The longer screws shown in red are for the grips and the blue for the rest of the controller.
After removing the grips, the 2 hidden screws should be visible as shown in image. After these are removed the controller is ready to be opened.
Insert a pry tool as shown in image next to the charging port to open the controller.
After it is opened you will work the tool around the controller until it is mostly open
After prying the controller, you will feel some resistance at the bottom of the controller as there are two clips either side of the headphone jack.
In order not to break the clips open the controller like a book in a motion portrayed by the arrow in the image. This is in an effort not to break the aforementioned clips
After we're in you'll be greeted by soldered in vibration motors, mainboard and a battery.
Detach the touch pad by flipping open the grey locking bale/tab on the FPC connector to disconnect the touchpad flex cable as shown in the image.
It is not necessary to disconnect the battery because we like living on the edge but if you do feel a need to do so this can be done by pulling the wires of the battery as closeto the battery connector and as straight as possible out of the mainboard.
To remove the mainboard and midframe in order to access the face buttons etc. We will have to remove two screws that the battery sits on top of.
Proceed to pull battery off to expose the 2 screws being mindful of the battery if it is still connected to the mainboard.
This concludes our teardown.
Note: Be careful not to lose things like the trigger springs, shoulder buttons and face buttons as they like to fall out.
