跳转到主内容
你所需要的
本篇指南是分解流程而非维修指南。 如果您要维修您的Revlon Perfect Heat Jumbo 3 Barrel Waver,应参考我们的维修指南
  1. Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Lever and Spring: 步骤 1 中的图像 1,3 Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Lever and Spring: 步骤 1 中的图像 2,3 Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Lever and Spring: 步骤 1 中的图像 3,3
    • Make sure your the device is unplugged before starting this teardown.
    • The device used in this tear-down is missing the lever and spring.
    • Remove these items by lifting up on the lever until it pops out of place. The spring should come out easily.
  2. Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Securing Screws: 步骤 2 中的图像 1,3 Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Securing Screws: 步骤 2 中的图像 2,3 Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Securing Screws: 步骤 2 中的图像 3,3
    • Remove all of the screws on the back of the plastic covering.
  3. Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Handle Casing: 步骤 3 中的图像 1,1
    • Remove the plastic handle cover by lifting it straight up.
  4. Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Circuit Securing Screw: 步骤 4 中的图像 1,2 Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Circuit Securing Screw: 步骤 4 中的图像 2,2
    • Remove the small black screw that is holding the circuit board in place.
  5. Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Power Cord: 步骤 5 中的图像 1,2 Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Power Cord: 步骤 5 中的图像 2,2
    • Remove the power cord from the power port of the Waver by holding the port with one hand and pulling on the cord with the other hand.
  6. Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Metal Heating Cylinders: 步骤 6 中的图像 1,3 Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Metal Heating Cylinders: 步骤 6 中的图像 2,3 Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Metal Heating Cylinders: 步骤 6 中的图像 3,3
    • Remove the two metal cylinders by sliding them down the length of the inner soft cylinders.
    • The internal ceramic cylinders are very soft and tear easily. Be careful not to damage them.
  7. Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Cylinder Securing Fixtures: 步骤 7 中的图像 1,2 Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Cylinder Securing Fixtures: 步骤 7 中的图像 2,2
    • Remove the plastic cylinder holders by lifting them up and along the length of the cylinder.
  8. Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Rear Metal Plate: 步骤 8 中的图像 1,1
    • Similar to step 4, remove the back metal plate by sliding down the length of the intern cylinder.
    • The internal cylinder is very soft and tears easily. Be careful not to damage it.
  9. Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Heat Control Dial: 步骤 9 中的图像 1,3 Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Heat Control Dial: 步骤 9 中的图像 2,3 Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Heat Control Dial: 步骤 9 中的图像 3,3
    • Gently lift the circuit board and tilt it to the side.
    • Lift the dial straight up from the circuit board. It should come off easily.
  10. Revlon Perfect Heat Jumbo 3 Barrel Waver Teardown, Full Teardown: 步骤 10 中的图像 1,1
    • Here are all of the safely removeavable components of the waver
Kyle Weeks
于09/26/12注册
122 声望
撰写一个指南
团队
Cal Poly, Team 15-45, Forte Fall 2012 Cal Poly, Team 15-45, Forte Fall 2012 的会员
CPSU-FORTE-F12S15G45
5 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 12
总计 861
