你所需要的
Remove the back fan grill from the case.
Unscrew the two PH2 black screws located on the back of the handle .
Fan speed, cold shot buttons, and rest of electronic components are nested in the handle section of the front case . These connect to the fan and heating coils in the shoot.
Cold shot button uses a TOPLY YSS-16 slide switch
High-Off-Low button is a 3 position slide switch.TOPLY YSS-16-2413.
Motor and open coils are closely soldered. There are 2 coils that control the temperature
Motor is yfd 385 2073 57
7 Fin PP impeller. This is tightly glued to the motor's shaft.
Uses a Hair Dryer Fan DC Motor yfd 385 2073 57
2条评论
Great share ! Thanks for the information in electronic sub assembly,You can find more details by visiting our site
