跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Retina MacBook 2016,请使用我们的维修手册
  1. Retina MacBook 2016 Teardown, Retina MacBook 2016 Teardown: 步骤 1 中的图像 1,2 Retina MacBook 2016 Teardown, Retina MacBook 2016 Teardown: 步骤 1 中的图像 2,2
    • With the MacBook jumping on the Rose Gold bandwagon, who knows what's lurking inside? Here's the lowdown so far:
    • 12-inch 2304 × 1440 (226 ppi) IPS Retina Display
    • 1.1 GHz dual-core Intel Core m3 processor (configurable up to 1.3 GHz dual-core Intel Core m7)
    • 8 GB of 1866 MHz LPDDR3 RAM
    • 256 or 512 GB PCIe-based flash storage
    • Intel HD Graphics 515
    • 802.11a/b/g/n/ac Wi-Fi wireless networking and Bluetooth 4.0
    • Single USB-C port and 3.5 mm headphone jack
  2. Retina MacBook 2016 Teardown: 步骤 2 中的图像 1,2 Retina MacBook 2016 Teardown: 步骤 2 中的图像 2,2
    • If it weren't for the rose gold finish, we'd be hard-pressed to distinguish between this year's Retina MacBook, and the one of yesteryear.
    • The exteriors look identical, from the Pentalobe screws in the lower case all the way down to the model number—A1534.
    • The only telltale sign that something's different is the updated EMC number: 2991 compared to last year's 2746.
  3. Retina MacBook 2016 Teardown: 步骤 3 中的图像 1,2 Retina MacBook 2016 Teardown: 步骤 3 中的图像 2,2
    • Popping the hood on this MacBook gives us an indication that the rose gold beauty is much more than skin deep.
    • Before delving any deeper into this beauty, we take a quick look at the chips powering the trackpad:
    • Broadcom BCM5976 touchscreen controller
    • STMicroelectronics STM32F103 32-bit ARM Cortex-M3 microcontroller
    • Monolithic Power Systems MP24830HL White LED driver and International Rectifier IRFH3702 power MOSFET
    • Maxim Integrated MAX11290 analog-to-digital converter (likely)
    • Macronix MX25L2006EZUI-12G 2 Mb Serial NOR flash memory
    • Maxim Integrated MAX9028 comparator
  4. Retina MacBook 2016 Teardown: 步骤 4 中的图像 1,1
    • Touchpad sensors:
    • Bosch Sensortec BMA282 accelerometer
    • Texas Instruments TMP421 temperature sensor
  5. Retina MacBook 2016 Teardown: 步骤 5 中的图像 1,3 Retina MacBook 2016 Teardown: 步骤 5 中的图像 2,3 Retina MacBook 2016 Teardown: 步骤 5 中的图像 3,3
    • What's that? The pesky tri-wing screw we saw last year grew another, um, wing—now it's a regular ol' repair-friendly Phillips.
    • If you weren't put off by the Pentalobes on the lower case, then a tri-wing probably won't slow you down much—but hey, we'll take what we can get!
    • Thankfully, all the other internal screws remain standard Phillips and Torx screws.
    • However, another surprise awaits at the hinge screws, whose Torx heads are filled with some sort of substance that disintegrates when you insert a screwdriver. Are you sealing our MacBook with tamper-evident screws, Apple?
  6. Retina MacBook 2016 Teardown: 步骤 6 中的图像 1,2 Retina MacBook 2016 Teardown: 步骤 6 中的图像 2,2
    • And at the other end of the MacBook, it seems the USB-C hardware has also changed. The cable is now perma-fixed to the USB board, condensing the two components into a single unit.
    • ...Also, the silicon is new and moved from the cable itself to the USB board. Here's a comparison of the new USB-C hardware (top) with that of the 2015 Retina MacBook (bottom).
    • Parade Technologies PS8741A (likely an iteration of the PS8740 USB-C redriving switch)
    • Diodes Incorporated PI1EQX7502 USB 3.0 redriver (likely)
    • NXP Semiconductor CBTL04043A1 4-Ch. bidirectional crossbar switch
    • This new USB and cable arrangement is one thing that's not compatible with previous Retina MacBooks.
  7. Retina MacBook 2016 Teardown: 步骤 7 中的图像 1,2 Retina MacBook 2016 Teardown: 步骤 7 中的图像 2,2
    • The battery's form factor seems 100% identical to the multi-lobed cell we found in the 2015 Macbook.
    • And yet somehow, Apple managed to squeeze in a 4% capacity increase from the 7.55 V, 39.71 Wh battery in last year's model. Apple claims this new 7.56 V, 41.41 Wh Li-ion power source should provide up to 11 hours of iTunes movie playback.
    • We're guessing this capacity increase is owed to improved battery chemistry (though it's also possible that Apple's engineers have shaved away just enough material from the lower case to allow for a thicker battery).
    • Unfortunately, they did not squeeze in any of those nifty adhesive pull tabs we've seen in Apple's iDevices.
    • Regardless, our tests indicate this beefier battery is compatible with last year's MacBook. Nice!
  8. Retina MacBook 2016 Teardown: 步骤 8 中的图像 1,1
    • Logic Board! What chips is this MacBook serving up?
    • Intel SR2EN Intel Core m3-6Y30 Processor (4M Cache, up to 2.20 GHz)
    • Toshiba TH58TFT0DFKLAVF 128 GB MLC NAND Flash (+ 128 GB on the reverse side for a total of 256 GB)
    • Micron MT41K256M16LY-107:N 512 Mb DDR3L SDRAM memory
    • Universal Scientific Industrial 339S0250 Wi-Fi module
    • Broadcom BCM15700A2 (as seen in several other MacBook models) webcam controller (likely)
    • National Semiconductor 48B1-11 (LP8548B1) backlight driver
    • Micron EDF4432ACPE-GD-F 4 GB LPDDR3 SDRAM Memory (with SSD controller presumably layered underneath)
  9. Retina MacBook 2016 Teardown: 步骤 9 中的图像 1,1
    • But wait, there's even more chips on the back:
    • Toshiba TH58TFT0DFKLAVF 128 GB MLC NAND flash memory
    • Samsung K3QF4F40BM-AGCF 4 GB LPDDR3 SDRAM (x2, for a total of 8 GB)
    • Apple 338S00066 power management IC
    • Texas Instruments/Stellaris LM4FS1EH SMC controller (replacement codename for TM4EA231)
    • Microchip (formerly SMSC) EMC1704-2 temperature sensor
    • Texas Instruments SN650839 step down DC-DC converter (likely), TPS51980A PMIC, and CD3215B01 USB-C controller
    • Intersil ISL95828 Intel CPU PWM controller
  10. Retina MacBook 2016 Teardown: 步骤 10 中的图像 1,2 Retina MacBook 2016 Teardown: 步骤 10 中的图像 2,2
    • IC identification, continued:
    • Renesas ISL95530 battery charger
    • Vishay SiC535 power stage
    • Maxim Integrated MAX98357B audio amplifier
    • Texas Instruments TMP102 temperature sensor
    • Microchip (formerly Atmel) AT93C66B 4 K serial EEPROM memory
    • Macronix MX25L2006EZUI-12G 2 Mb flash memory
    • Texas Instruments INA211 and INA214 current sense amplifier
  11. Retina MacBook 2016 Teardown: 步骤 11 中的图像 1,2 Retina MacBook 2016 Teardown: 步骤 11 中的图像 2,2
    • Retina Macbook 2016 Repairability Score: 1 out of 10 (10 is the easiest to repair)
    • Those pesky tri-wing screws are gone, replaced with lovely standard Phillips screws—but tamper-evident hinge screws make you feel like a hoodlum for repairing your own machine.
    • The processor, RAM, and flash memory are still soldered to the logic board.
    • The battery assembly remains entirely, and very solidly, glued into the lower case.
    • The Retina display is still a fused unit with no separate, protective glass. If the display needs replacing, it'll cost a pretty penny.
    • While it's no more repairable than last year's edition, it does benefit from sharing a lot of the same parts and repair procedures.
Evan Noronha
于02/05/15注册
224,065 声望
创作了168篇指南
50条评论
Step 8, Apple 338S00066 should not be the SSD controller. It might be the audio codec.
Step7, The SSD controller should be under the chip "F4432ACPE-GD-F".
JJ Wu - 回复
It's been reported that the new Apple designed SSD controller sits next to the NAND flash chip instead of under it.
eric.summers -
Yes. Apple designed SSD controller is next to the NAND flash chip as Step 7 shown. F4432ACPE-GD-F chip is next to Toshiba NAND Flash chip. SSD controller needs memory. In 2015 model, Apple uses PoP package to put it upon the SSD controller.
MacBook 2015 款 Retina 屏幕版本拆解 Step 14
JJ Wu -
So how much RAM in total does it have? 4GB Micron (Micron MT41K256M16LY-107 4Gb DDR3L SDRAM) plus 8GB Samsung (Samsung K3QF4F4 4 GB LPDDR3 RAM (x2, for a total of 8 GB)) ?
JA VE - 回复
4Gb -> 512MB, more likely for SSD cache
mesish -
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 77
过去 30 天: 360
总计 220,060
