简介
Here's a Blackberry Pearl 8130 for disassembly. It had software issues which I afterward fixed.
你所需要的
Frontal/Back View- Dimensions: (LxWxD) 107mm x 50mm x 14mm (4.02" x 1.97" x .55") <- For those in America :) Weight: 96g or 3.10oz
Speaker
Status LED
High-res 240x260 Color LCD display
Red Trackball
1.3MP Camera
Flash
Back Cover Latch
Insert curved point metal spudger into gap between keyboard and bottom bezel cap.
Bottom Bezel Cap
Pull up and push away to lift bezel.
Hold this cap with your thumb and flip the phone around.
Insert spudger under bezel and lift on both sides.
Pry Here
The Bezel Cap should pop off at this point revealing two more T5 screws!
Two T5 Screws
Remove the two T5 Screws and set them aside.
The two T5 screws and their respective holes
Start at the top of one of the sides of the phone and pry off the silver sides with a spudger or your fingers.
Once you have removed both sides set them aside
The silver sides
Various holes, buttons and slots
Trackball (Removable). Pop it out from the back.
Display Glass (Removable). Pry from the top to break glue seal, pry the rest of with your fingers.
Keypad
LCD and connector above it to the left (Removable). Remove connector with spudger and free LCD from clips.
Keypad connector (Keypad was removed). To remove pry connector up off of logic board.
Battery Connector
Various chips under metal heat sinks. Sorry I won't remove them the phone is still good and I don't want to risk damaging it :(
Speaker (Removable by Soldering)
Keyboard Connector
Trackball (Remove by poking out)
1.3MP Camera (Removable by Soldering)
From left to right: Headphone jack, Antenna?, USB Port, Micro SD Card Slot. All of the above are removable by soldering.
Battery Connector (Removable by pulling it straight out of it's slot)
Various chips covered by heatsinks
