拆解
本篇指南是分解流程而非维修指南。 如果您要维修您的NES Cartridge,应参考我们的维修指南。
Flip the cartridge face-down on your table.
Use a 3.8 mm gamebit screwdriver to undo the 3 screws on the rear of the cartridge, and set them aside.
Gently lift up the half of the cartridge facing up, and set it aside.
Gently lift out the PCB, and clean the pins with isopropyl alcohol and a cotton swab. if the pins still remain dirty, carefully sand the pins with a very fine-grit sandpaper.
与3其他贡献者
于03/24/22注册
109 声望
撰写一个指南
徽章: 0
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 17
过去 30 天: 97
总计 2,444
