跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Protoss Pylon,请使用我们的维修手册
  1. Protoss Pylon Teardown, Protoss Pylon Teardown: 步骤 1 中的图像 1,1
    • Here's what we theoretically know about these pylons:
    • Uses Khaydarin crystals to channel energy
    • Takes 100 minerals and 30 seconds to warp in
    • Floats in the air and glows
    • Provides supplies for 8 units
  2. Protoss Pylon Teardown: 步骤 2 中的图像 1,2 Protoss Pylon Teardown: 步骤 2 中的图像 2,2
    • Scientific analysis of our "prototype" specimen yields the following data:
    • 2 unregulated USB ports capable of sourcing 2A total (or whatever max current it's supplied with)
    • The crystal can be activated to glow blue with a switch
    • Prototype: must be powered by a wired 5V 2.1A DC power supply
  3. Protoss Pylon Teardown: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    Manta Driver Kit - 112 Bit Driver Kit
    $69.95
    购买
    • Luckily, we just got a shipment of high quality tools! And, they're so nice looking!
    • It's slightly unsettling that even the Protoss are using Phillips screws. It must be a universal standard.
    • The only thing worse than esoteric screw types? Low quality ones. These screws are made of soft metal and are easily stripped. This must be a side-effect of their warp-in technology.
    • Since most skirmishes last less than an hour, it looks like this field pylon wasn't built to be durable.
  4. Protoss Pylon Teardown: 步骤 4 中的图像 1,2 Protoss Pylon Teardown: 步骤 4 中的图像 2,2
    • The clever Protoss thought they could hide their technological secrets behind a seemingly impossible to open enclosure. They obviously have not met the masters of the art.
    • We apply pressure with an opening pick at just the right place, and off pops the stabilization leg.
  5. Protoss Pylon Teardown: 步骤 5 中的图像 1,3 Protoss Pylon Teardown: 步骤 5 中的图像 2,3 Protoss Pylon Teardown: 步骤 5 中的图像 3,3
    • Wait, who removed the other stabilization leg? That will cau...
    • Phew! It looks like the sensitive monitoring equipment survived the explosion. After we scrape up the charred remains of the interns, we shall proceed as planned.
  6. Protoss Pylon Teardown: 步骤 6 中的图像 1,2 Protoss Pylon Teardown: 步骤 6 中的图像 2,2
    • And here we see the casualties of the warp-in technology:
    • Energy transfer conduits that are dangerously pinched
    • Low reliability conduit-to-socket connections
    • These are weak points which will most likely fail before anything else. When it happens, repair should be simple. Inte...er... someone should note this in our files.
  7. Protoss Pylon Teardown: 步骤 7 中的图像 1,2 Protoss Pylon Teardown: 步骤 7 中的图像 2,2
    • We finally get a glimpse of the Protoss' power channeling circuitry.
    • It is surprisingly sparse and low tech, consisting mostly of surface mount resistors and common electronic components...
  8. Protoss Pylon Teardown: 步骤 8 中的图像 1,3 Protoss Pylon Teardown: 步骤 8 中的图像 2,3 Protoss Pylon Teardown: 步骤 8 中的图像 3,3
    • We've been bamboozled by the Protoss! This isn't a real pylon; it's just a toy! A decoy!
    • Contact our field agents and fire them! Literally, with a Firebat executioner squad.
    • Speaking of being fired, someone’s going to have to take the fall for this. Wait right here! I’m going to go check on…something in the hanger bay…
6条评论
I thought that humans would get that long-awaited technology ... it seems that we will have to continue using crank motors ... This afternoon I may release zerg eggs on some of their planets :)
Oscar - 回复
Ya’ll are nerds. Wonderful, wonderful nerds.
Sandy34 - 回复
My life for Aiur!
Reza Sadr - 回复
On the main circuit where the DC socket is under the socket i fount no metal to solder for. They ‘ve actually solder the connector pins to plastic. Cheap work for 40Eur. You need to sratch the blue part to find some contact spot.
magortomi - 回复
Fairly disappointed with this thing and the quality of the electronics but alas, it’s a toy made in china. Took me about 4 years to get around to it but I finally fixed the faulty power connector thanks to you guys. Thank you so much for this. I could not figure out where those clips were behind the larger sides.
Logan - 回复
Same here, thank you so much for this guide, the connector on my pylon became loose to the point where I have to apply downward force onto the power connector in order for it to light up. After about 5 years now I am finally able to open it up to try to repair it, thanks for the guide!
scwashere -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 27
总计 5,922
