在此拆机指南中的精选工具
简介
Going to take apart my Power Mac 8600/250!
Tools:
#1 Phillips screwdriver
Spudger/Flathead screwdriver
Your hands!
这个拆解是不是维修指南。 要维修你的的Power Macintosh 8600(250),请使用我们的服务手册
There she is! i'm missing the bezel around the floppy drive :(
  • There she is! i'm missing the bezel around the floppy drive :(
添加评论
Start by pressing the big green button. And pulling the door away and up from the computer. And on the Back of the door is the fan. And on the Back of the door is the fan.
  • Start by pressing the big green button. And pulling the door away and up from the computer.
  • And on the Back of the door is the fan.
添加评论
Now it's best to lay the computer flat. And to flip up the tabs, grab the handle and open. And to flip up the tabs, grab the handle and open.
  • Now it's best to lay the computer flat.
  • And to flip up the tabs, grab the handle and open.
添加评论
The innards, motherboard, daughter board, RAM and so fourth.
  • The innards, motherboard, daughter board, RAM and so fourth.
添加评论
Now the speaker Remove the speaker wires And the fan wires from the motherboard
  • Now the speaker
  • Remove the speaker wires
  • And the fan wires from the motherboard
  • Push in the two plastic tabs on either side and lift the speaker up and out.
添加评论
The PRAM battery! Remove the housing by pulling it out and then take the battery out.
  • The PRAM battery!
  • Remove the housing by pulling it out and then take the battery out.
添加评论
The processor, firmly grasp and pull out. Remove the 4 #1 Phillips screws And push the 4 tabs off of the board
  • The processor, firmly grasp and pull out.
  • Remove the 4 #1 Phillips screws
  • And push the 4 tabs off of the board
High failure rate - these bassas’
Mal - 回复
Any video card or usb card, mine happens to be an ethernet 10/100 card.
  • Any video card or usb card, mine happens to be an ethernet 10/100 card.
  • Unfortunately there are 6 spaces but only 3 slots on the motherboard :(
  • Remove the #1 Phillips screw and pull the card out.
添加评论
RAM and VRAM slots!
  • RAM and VRAM slots!
添加评论
Moving on to the CD, ZIP, and Floppy drives (best to close computer now) Remove the bezels and if I had the top one remove that too. Remove the 6 phillips screws and pull the metal frames out.
  • Moving on to the CD, ZIP, and Floppy drives (best to close computer now)
  • Remove the bezels and if I had the top one remove that too.
  • Remove the 6 phillips screws and pull the metal frames out.
添加评论
Remove the data and power cables Pay special attention to this one, it has a clip on it, it helps to use a flathead or a spudger. Pull the drives out of the bay.
  • Remove the data and power cables
  • Pay special attention to this one, it has a clip on it, it helps to use a flathead or a spudger.
  • Pull the drives out of the bay.
添加评论
Now the hard drive. Remove the two phillips screws
  • Now the hard drive.
  • Remove the two phillips screws
  • And the data and power cables (might help to remove them as you pull the drive out)
添加评论
The power source Remove the two connectors There is a clip holding the wires in place. Separate and remove the wires. (both sets)
  • The power source
  • Remove the two connectors
  • There is a clip holding the wires in place. Separate and remove the wires. (both sets)
添加评论
Now remove the 4 phillips screws (it's best to start with the bottom two) And pull it out while de-threading the wires. And pull it out while de-threading the wires.
  • Now remove the 4 phillips screws (it's best to start with the bottom two)
  • And pull it out while de-threading the wires.
添加评论
Plague
于2010年06月14日注册
151 信誉积分
撰写一个指南
Nice. I got a beige G3 300 Mhz, the case is similar. Maybe I could also make a teardown.
Nicolas Zbinden - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 5
过去的30天: 28
总计 13,148
