简介
This guide is for my engineering class. My goal is to show you how to fully gut a Power Mac G4.
你所需要的
Use a flat head screwdriver or spudger to lift up the tabs that hold down the heat-sink.
Repeat x2
The heat-sink should just lift right off.
Remove highlighted cables.
Remove highlighted screws.
Lift out the motherboard. (Note: pull to the left to clear the ports from the case)
Remove the face plate. You are supposed to press down the highlighted tabs from the inside.
Slide out the drive. (MAKE SURE TO UNHOOK THE CABLES)
Remove the highlighted cables.
Remove highlighted screw.
Lift out the hard drive.
Remove highlighted screw. ( SAME SCREW ON OPPOSITE SIDE, REMOVE THAT AS WELL.)
Disconnect the connector.
After that, just pull it out.
Use a 2.5 mm hex key to remove these screws.
Feed the wires through the highlighted hole, then pull out the power supply.
4条评论
The is a kit from thelaserhive.com to allow an mATX board to be used inside the G4 cases.
como retiro las tapas de los lados para hacerlelimpieza
Sieh hier nach
