跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Table Lamp,请使用我们的维修手册
  1. Portable Luminaries Lamp Teardown, Portable Luminaries Lamp Teardown: 步骤 1 中的图像 1,1
    • The attached picture displays the lamp before the teardown.
  2. Portable Luminaries Lamp Teardown: 步骤 2 中的图像 1,1
    • Remove the power cord from the wall socket outlet
    • Make sure to follow this step. There may be a danger of severe electric shock if you proceed to tear down the device without removing the plug
  3. Portable Luminaries Lamp Teardown: 步骤 3 中的图像 1,2 Portable Luminaries Lamp Teardown: 步骤 3 中的图像 2,2
    • Place the lamp gently on its side on a flat surface
    • Twist the lightbulb counter-clockwise to remove it from the lamp's head.
    • After lightbulb removal, the component attaching the lightbulb and lamp's head is exposed.
  4. Portable Luminaries Lamp Teardown: 步骤 4 中的图像 1,2 Portable Luminaries Lamp Teardown: 步骤 4 中的图像 2,2
    • Next, the light bulb housing can be detached from the lamp head
    • Using the Philips screw driver, unscrew the two 5mm diameter screws within the light bulb housing
  5. Portable Luminaries Lamp Teardown: 步骤 5 中的图像 1,2 Portable Luminaries Lamp Teardown: 步骤 5 中的图像 2,2
    • Keep the lamp on its side
    • The bottom is now exposed and two screws are visible
    • Using the Philips Screwdriver, unscrew the two 7mm gold screws from the bottom of the base
  6. Portable Luminaries Lamp Teardown: 步骤 6 中的图像 1,2 Portable Luminaries Lamp Teardown: 步骤 6 中的图像 2,2
    • Once the screws attached to the base are removed, the base's bottom lid detaches from the lamp.
    • Within the base resides two components: the lamp's weight and the switch.
    • The weight sits on the bottom base lid, so it separates without the use of additional tools.
  7. Portable Luminaries Lamp Teardown: 步骤 7 中的图像 1,1
    • The white container holding the switch does not need tools for opening.
    • The switch container is clipped shut and opens by unlatching the tab
Brenden
于11/17/14注册
56 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 25
总计 1,686
