简介
本指南将会向你展示如何彻底拆解你的相机。
你所需要的
将电池/相纸盒模块完全打开。
My film door latch came off the camera and I can’t get the film door open ? Help.
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
10条评论
Is it possible to remove and change the camera straps for this camera?
Yes, after step 8 you will have the back case free then in the inside you will see the latches of the plastic plate that holds the strap, pry them carefully are 6, 2 on each side and 2 in the middle, in the middle of doing it myself have stopped since was no need for that so cannot tell you more.
RAW Fish: Get a terminal driver or other thin device, and wedge it where you can see a line between the outer casing and front panel (where it says “Polaroid” with the rainbow logo). This will need a bit of brute force, but you will be able to seperate a right-angle of outer casing, from the back of the flash, and another right angled bit full of electrics and the front panel. DO NOT touch any of this electrical gubbins - discharging the capacitor through your fingers will HURT. From here you can take out the circuit board and do with it what you wish.
Ariane N -
Hi ! Thanks for your article ! I just bought a Barbie polaroid 600 ;) but unfortunately the flat wire between the camera the flash is disconnected (it dangles from the camera). I managed to remove the flash, that is no longer connected. Do you know how can I open the flash part to reconnect the wires ? Thanks ;)
Is it possible to reassembly the camera after the teardown?
I just got a cámara however the button for the flash or picture does not work is there a way to repair it ?
I have a question are all of the gear supposed to spin smoothly? Or with slight pressure my buck black vision hear on the right side is not moving it on movies when the little silver one on its side moves
On step 20, the spring thing, does anyone know its dimensions or where i can buy it? Its missing from my polaroid cam that doesnt work.
